Sump gaskets
Results 1 to 7 of 7
Thread: Sump gaskets
    1,389
    Default Sump gaskets
    Got my sump today (thanks Cam) Xu10 with trap door. What way do I go regarding the gasket as I'm using a 15mm spacer as well.
    Do I get two pre fab gaskets - one for the spacer and one for the sump?
    Do I just use a gasket goo / silicone?
    Moo
    5,699
    I use threebond - forget the exact type but just consult their charts.
    "The enemy of knowledge is not ignorance, it's the illusion of knowledge"
    Stephen Hawking
    Jan 2011
    Traralgon
    649
    Use a good quality gasket in a tube for the top side of the sump ladder.
    I have never worked on a XU10 block, is it drilled and tapped for the sump ladder retaining bolts?
    Only use the gasket between the sump and the ladder.
    racing 405
    1:59:09 last time at Phillip Island - less than standard Mi16.
    9,562
    Quote Originally Posted by PugMonkey View Post
    Moo
    Gasket is just for the steel sump, just use silicone or better still the anaerobic sealing compound.
    Graham
    7,569
    No such thing as a gasket on the alloy sumps. Use ThreeBond 1211. Don't use gasket goo, guttering strength silicone or that black crap that others use. Just put a smear of 1211 on each of the four faces and bring them together when tacky. If you ever have to pull it apart you'll appreciate it even more.
    1,389
    Thanks everyone, I'll be going the threebond 1211. I'll trace some down today.
    Moo
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,016
    dont speak evil of silastic! my favourite tool of the trade behind q-bond, big hammers and excessive force
