MI16 - 8 Port manifold question
    I might be slow... DRTDVL's Avatar
    Auckland
    1,288
    Default MI16 - 8 Port manifold question
    Hello everyone...
    Please excuse me if this sounds loopy, which it might as i'm still wired on pain med's from a knee op today.
    With the 8 exhaust port mi16 head, do most people just make a extractor to cover both ports per chamber or do they make them individual ports that merge later?
    If it's 4 covering all 8 do they make it like a standard port where the two valve seat opening blend into a single port?
    If not wouldn't that effect the performance of the flow into the exhaust manifold?
    again sorry if it doesn't make sense - i feel like i'm floating at the moment.
    7,567
    You make a collector which covers the two ports, the angle of which must be 6 to 9 degrees max. Then the four pipes join again in another collector.
    Auckland
    1,288
    sweet my hazzy mind had it correct then.
    Thanks for that Peter...
    Jan 2011
    Traralgon
    649
    You can buy a very tidy set of stainless extractors with 8 into 4 into 1 configuration from a crowd in Holland. I have a set on my 405, but they would clash with power steering on the 405 (mine was already gone).
    They actually whistle a little bit, sounds almost like turbo'd on a trailing throttle at high engine revs. Can't comment on performance yet, haven't had it back on the dyno since they were fitted.
    Not that expensive either.
    racing 405
    1:59:09 last time at Phillip Island - less than standard Mi16.
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,360
    I always thought the mi16 had a really nice set of standard extractors, how much can you improve on them?
    2017 Renault Koleos auto
