205 gti compression ratios
Results 1 to 11 of 11
    Fellow Frogger! chez00's Avatar
    567
    Default 205 gti compression ratios
    Hi all,
    Just bought a very tidy 1988 205 gti and I'm in love.
    I was wondering if anyone can tell me the compression ratio of the aussie 205 gti as I've heard it's lower than the Euro spec. I apologise if this has been asnwered elsewhere - I did search but couldn't find anything.
    If it is lower, what creates the variation? i.e. piston compression height, bigger cylinder head chambers.
    Chez
    7,568
    Depends on which model/engine code, but both lower the European version at 9.6:1. Yours will be DFZ.
    S1/S2 with DFZ engine: 8.4:1 from small dish in piston and large chamber
    S3 with DKZ engine: 9.2:1 from large dish in piston and small chamber
    567
    Thanks Peter.
    8.4! Sounds like I'd need to hunt a DKZ head if I want to up the compression for a longer duration cam. Is this the path people usually go with these things if they're chasing a bit more poke but keep the 8v?
    Fellow Frogger! DjB8V's Avatar
    8V'ville
    921
    Yep
    DFZ/DKZ combo gives 10.5:1 and with a cam, quite a hot package. I have driven a 205 with this setup and it goes very nicely
    9,562
    Quote Originally Posted by chez00 View Post
    Thanks Peter.
    Be careful, you may find as I did that the compression is too high.
    I had around 230 psi compression readings and even with programmable timing couldn't stop it pinging on 98 octane.
    Even my UK spec 1.9 8 valve is on the verge of pinging with 9.6 to 1, standard distributor, but soon to get aftermarket management.
    Graham
    567
    Hmmm. Is this to do with chamber shape or something? 10.5 although high is not outrageous. I've built an Alfa GTV with around 11:1 and no ping issues - with heavily domed pistons.
    Anyone have/know of a DKZ head for sale, or where to get one?
    Thanks,
    Chez
    8V'ville
    921
    I have one in bits....
    Sling me your email and ill take some photos and send them to you
    9,562
    Thanks,
    Chez
    I have a complete one on a 205 Si motor, same as DKZ in the head.
    Graham
    9,562
    Thanks,
    Chez
    Seems to be a common problem with Peugeot engines, I remember the 504 1.8s used to ping badly on 8.3 to 1 and this was in the days of high octane leaded fuel!
    Graham
    1,389
    Thanks,
    Chez
    Geez I just sold one that was reconditioned for a hundred bucks. (the guy has paid but hasn't collected it yet)
    567
    Quote Originally Posted by PugMonkey View Post
    Woulda been nice
    Can't win em all.
