206 GTi short motor
Results 1 to 7 of 7
    Fellow Frogger! aquinian's Avatar
    WA
    604
    Default 206 GTi short motor
    Hi all,
    Does anybody know whether the bottom end of the 206 GTi motor (2002) is identical to the 8-valve version, or indeed any other variant? I believe that the motor is the same one that powers the 307.
    I have scored big-end journals and I am looking at swapping the bottom end if possible/cheap.
    John.
    Current: 406 Coupe, 504 Sedan
    Previous: 306XSi, 205GTi, 206Gti, 505 V6, 505 Wagon, 504 Sedan, 504 Wagon, 306Gti6, 306XT, 205Si, Citroen XM, Citroen Xantia
    Sep 2003
    North Parramatta
    4,038
    Quote Originally Posted by aquinian View Post
    Hi all,
    John.
    8 valve version of what? The XU10?
    The EW10J4 appeared in late model (1999 and on) 406s, every 206 GTi and all 2 litre 307s delivered in Oz. They are all 16V motors with an alloy block. Later models (EW10A) have VVT, but I don't think the block was changed much.
    I must admit, I'm not sure if they are at all similar to the XU10 motor bottom end, but I suspect not.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    WA
    604
    Thanks for replying. I understood there was an 8-valve version of the EW10J4. I'm in error? That's good. That means more sources of donor engines, I expect. Or is there an unrelated engine fitted to non-GTi 206s?
    Do you know where I can find a list of vehicles with the engine?
    Sep 2003
    North Parramatta
    4,038
    The 206 (as delivered in Australia) came with two engines: a 1.6 and a 2.0 engine. The 1.6 initially was an 8V engine, before being sold exclusively as a 16V version, whereas the 2.0 was always a 16V motor.
    I've listed all the models that it came with, but you're looking at post update (or D9) 406s, all 307s and all 206 GTis. 2005 model 307s and 206 GTis have the EW10A with VVT on the inlet cam.
    Simon
    1000+ Posts TroyO's Avatar
    2,514
    The 206 GTi never came with the EW10A, only the EW10J4.
    Sep 2003
    North Parramatta
    4,038
    Quote Originally Posted by TroyO View Post
    Thanks Troy.
    I probably shouldn't post straight after nightshift.
    Simon
    WA
    604
    Thanks guys for the info, much appreciated. David Cavanagh is supplying a motor.
