206 engine, how much?
Results 1 to 16 of 16
    Tadpole NIKOFF's Avatar
    Feb 2006
    15
    Default 206 engine, how much?
    hey there all, i am interested in performing a 206 engine conversion in my AX, some people from england have told me that the 206 engine (pre multiplex models) is a detuned version of the saxo vts engine, which is simple to install into an ax. so i was just wondering, what would it all be worth to do??? i would initially need a 206 engine complete with wiring harness. anyone got any ballpark figures as to the cost of this? some of the guys in the UK have their ax's fitted with saxo vts engines running 13 second quarter mile passes, now thats as fast as a hsv. dunno bout u, but that sounds like a right laugh. so anyone with some price estimates would be greatly apreciated.
    the frog family collection-
    -CITROEN-
    xantia exclusive
    bx 19 tri estate
    bx 19 tri 122 hatch
    bx 19tzi hatch
    '74 SM injection
    ax GT <- this one is mine
    -RENAULT-
    megane convertible (soft top)
    Country Victoria
    49
    Default 206gti into 306
    AT the moment we are looking at putting a 206gti engine into a 306 3door that we resently aquired. and building it into a track/race car.It would be interesting to find out if anybody has done this here. I have found a website in the uk where somebody has done that. and also put a gti 180 engine into a 205 gti.
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    With so few good examples of AX's in Aust is it wise to butcher one ???
    - xTc -
    Now this is a .sig
    Banned orestes's Avatar
    Sunshine Coast
    4,520
    Quote Originally Posted by XTC
    - xTc -
    I say let the guy do what he wants, this forum is full of to many nay sayers when it comes to modifying cars from stock. You're going to get about as much money for an AX as my 5 door 205 as well so I don't see the worry of going backwards when you come to selling as you're already about as far back as you're going to get in terms of what the car is worth now. try http://www.partslocator.com.au/ to source an engine, and then get a quote.
    Ipswich, Queensland.
    1,976
    Perhaps watch the damaged car auctions. If one is unable to be
    re- registered you are likely to get it fairly cheaply
    '56 Renault 4CV (16TS Power)
    '62 Renault Dauphine Gordini
    '82 Renault Fuego GTX
    9,570
    Quote Originally Posted by NIKOFF
    The 206 has a TU engine but is cast iron, the main attraction of the AX is its light weight so may not be such a good idea.
    Graham
    Country Victoria
    49
    Default 206gti
    If you pick up a 206gti at a damaged auction then you have a nice alloy engine.
    9,570
    Quote Originally Posted by Slvr205GTi
    But a bigger one, still heavy, but wouldn't it go!!
    Graham
    1000+ Posts Dave's Avatar
    Apr 2001
    1,339
    Graham
    There is no was an xu or ew engine would fit in an Ax, have to stick with tu's.
    Dave
    Feb 2006
    15
    Quote Originally Posted by Dave
    Dave
    yeah, the gti engine wont fit, but the stock 16v engine will.
    the other option is to always look into forced induction, that way, the engine is retained to keep it lightweight and it could be removed again to retain origionality. the only down side is being able to find computer system to run the whole thing... hmm well all good fuel for thought, thanks guys
    -CITROEN-
    xantia exclusive
    bx 19 tri estate
    bx 19 tri 122 hatch
    bx 19tzi hatch
    '74 SM injection
    -RENAULT-
    1000+ Posts U Turn's Avatar
    1,761
    Have you looked at the xu10j4rs engine from the gti6? at least you wouldn't have to frig around with engine mounts etc as it should all bolt straight in?
    Take the long way home....
    - 306 gti6
    Fellow Frogger! AxGT's Avatar
    Apr 2001
    308
    The iron block 1.6 16v will fit. But you will need different engine mounts, different drive shafts, different hubs, maybe different suspension struts, and different wheels (the different hubs are 4 stud)
    Realistically, your best bet is to see if you can get a Saxo VTS front cut from NZ, as it will have everything you need, and will allow you to transfer everything across. You'd probably also want the Saxo rear axle, to get the rear disks, and 4 stud hubs.
    Ken
    Apr 2001
    308
    Also, apparently the 1.6 16v head will fit the 1.4 Alloy block with some minor modifications - that might be a better path to go down, as it involves heaps less changes.
    1000+ Posts brenno's Avatar
    1,937
    A replacement TU block and head for our 307 came in at around $13K in just parts, so I'd reckon you'd be better of looking in wrecking yards.
    Fellow Frogger! enthused!'s Avatar
    Jul 2004
    Sinney
    439
    - xTc -
    if it's an AX GT there's only 7 of them left.
    1992 mi16 1.9 litre - it's a love hate realtionship.
    whatever you do NEVER tell anyone your car is reliable. doesn't matter how much wood you touch!
    previous cars: peugeot 306xt, peugeot 205si, renault 20, renault 12 - sedan and wagon, renault 25, alfa 155 twin spark
    Apr 2001
    308
    Really,
    How do you figure that? - there were ~50 imported, so thats a pretty high mortality rate
