my 205gti front end
    Member mi205's Avatar
    Nov 2003
    belgrave melbourne
    75
    Default my 205gti front end
    hey guys,
    ok so i have had some minor problems with my front end.is it possible that some one could inform me of what thing mite normally go wrong with them.since the koni's have been in and over the last two years it have become loose and sloppy.
    i have done the upper strut tower things.and the wish bone bushes but still no real luck.i thank it is the upper and lower control arms/bushes, could this be right?some general help or anyone that has done there front end recently or ever could help.
    thanks jordan
    Apr 2005
    4
    I'm no expert by a long shot, I just had the sway bar link rod replaced on my 205 recently. Prior to this it was very loose when it was cold and had a knocking sound. It is a whole lot better now. The mechanics replaced the top strut bushes as well. Hope that helps!
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Id start with the basics, such as ball joints, steering & control arms, get each front wheel of the ground and see if it wobbles vertically or horizontally (with the streering locked) If you have play it would be worth getting a pro to look at it. - Chris
    ... ptui!
    Ipswich, Queensland.
    1,976
    Not that it is quite the front end, but upper and lower engine mounts break on these cars from time to time.
    '56 Renault 4CV (16TS Power)
    '62 Renault Dauphine Gordini
    '82 Renault Fuego GTX
    Brisbane, QLD, Australia
    396
    Check your front sway bar rubbers as well, that and the engine mounts as suggested.
    Did you change the front springs when you replaced the shockers?
    Chip
