505 GTI ZDJL Cam profiles..
Results 1 to 3 of 3
    Dec 2004
    England
    33
    Default 505 GTI ZDJL Cam profiles..
    Hi
    Does anyone have the data on the cam profiles (lift, duration etc..) for both the unleaded and leaded 505 GTI engines?
    David
    Feb 2002
    Tamworth NSW
    496
    Icon7
    Good question!
    I do agree that the leaded engine has a different cam profile, which, amongst some other differences, enables this engine to produce more HP than the unleaded engine.
    I will research & advise of any information.
    Kim.
    Fellow Frogger! sapito's Avatar
    Apr 2004
    128
    I found out today the later j7t engines have the alloy rocker arm followers and some models have longer camshaft contact points which allow bigger cam angles.
    However the best cam is supposed to be a 260/270 degree one as it allows this engine to idle properly without stalling as do larger cam choices.
