Should the rev limiter on a 306 s16 kick in before the redline?
    Jan 2006
    Wamuran (hr nth of Brisbane)
    50
    Default Should the rev limiter on a 306 s16 kick in before the redline?
    I would have thought no. At the moment I can't actually rev the car to redline (7000RPM going by the gauge) as the fuel is cut before it. Is this right?
    '94 306 s16
    '91 RGV250
    Economics exists to keep Economists in jobs.
    1075.6 SamR's Avatar
    May 2004
    1,392
    Certainly doesn't sound right. I thought the cutout was usually a few hundred rpm higher than the redline.
    1989 205 Gti - Sold
    "This year, I invested in pumpkins. They've been going up the whole month of October and I got a feeling they're going to peak right around January. Then, bang! That's when I'll cash in." - Homer Simpson
    Fellow Frogger! biologist's Avatar
    867
    Quote Originally Posted by Valentino_Rossi
    You sure its the fuel being cut?
    Rev limiters normally cut the ignition power.
    Is the engine warm enough? Some ecu's won't
    allow the full rev range until hot enough.
    Biologist
    A
    one Megane Family
    Jan 2006
    50
    yeah, probably the ignition being cut. I knew it had to be one or the other to 'die' like it does, although how do they implement a rev limiter on a carburettored 2 stroke motorbike? I digress..
    Well I'd driven the car for 10km+ with a temp >80 deg C. Would that pull the rev limiter down?
    '94 306 s16
    '91 RGV250
    867
    Centrifugal cutout? No idea, would be interesting to know...
    Hmm, should be warm enough, maybe the rev counter is out?
    Biologist
    A
    one Megane Family
    1000+ Posts Dave's Avatar
    Apr 2001
    1,339
    as above the tacho is probably not accurate
