205 clucth cable mount bracket findings.
Results 1 to 7 of 7
    Jul 2004
    nth balwyn, victoria
    1,428
    Default 205 clucth cable mount bracket findings.
    i dropped in to the mechanics and he showed me something interesting.
    he is putting a new clutch in a 205 gti and showed me why the customer was complaing if not being able to select gears properly apart from the worn clutch.
    the bracket where the clutch cable adjustment end is had actually started to open up at the cylindrical housing that takes the adjustment mechanism.
    this is usually a small cast tunnel attached to the end of a bracket but had cracked and was opening up more and more with use.
    no wonder the cable wasnt doing its job properly.
    ill post some pictures tommorrow to explain it better.
    so if your having selection probs,check this mechenism.-BAZZ
    BAZGTI
    87' 205 gti anthacite grey
    electric sunroof/tinted windows
    koni yellow adjustables/sparco strut brace.
    15" polished speedlines.
    momo steering wheel.
    Member fat bastard's Avatar
    Nov 2002
    Perth WA
    114
    Default cable bracket
    Same thing happened to me - I kept driving and was going to get a new one but it broke totally off the next day in peak hour traffic!
    Present: 406 petrol 2.0 turbo 97(GB Import), 205 gti 1.9 89, Yamaha TZR250 3xv 93 (Jap Import)
    Past: 205 gti 1.6 1988 (Singpr Import), Citroen 1.9 BX16valve, 405 1.9 mi16, 405 2.0 mi16,
    205 si 93, Mini GT, Datsun SSS x3, Dodge Ram, kingswood, Yamaha TZR250 2ma x2
    Hey mate...You've left your Barina's lights on
    1075.6 SamR's Avatar
    May 2004
    1,392
    Yikes I think I'll keep an eye on that part so the same doesn't happen to me. Thanks for the info Bazz
    1989 205 Gti - Sold
    "This year, I invested in pumpkins. They've been going up the whole month of October and I got a feeling they're going to peak right around January. Then, bang! That's when I'll cash in." - Homer Simpson
    Aug 2005
    Liverpool NSW
    317
    yes im having selection problems & thanks. some pics would be great.
    Puggy.
    Tadpole Drevlin's Avatar
    12
    It was my car that was at the mechanics, and I've actually got it back after 3 weeks. Replaced CV shafts and clutch at the same time. As Baz said the gear selection problem was due to the clutch fork and not the cable. The fork was about $70.00 but it took a while for it to get from Sydney to Melbourne. If I had read this post earlier I could have taken the part home and taken pictures of it. I'll go in on Monday to see if the fork is still there.
    Jul 2004
    1,428
    its still there mate,i took some piccies which ill try to upload now,ive been having problems uploading piccies since i got the new computer.-BAZZ
    BAZGTI
    ACT Australia
    32
    yeah similar thing fo me, except the end of the cable brokke off as well
    luckily i managed to shift without the clutch, bit clinky but still works if u match the revs.
    had to replace fork as wel.
