306 Front Speakers?
    Tadpole C_Balls's Avatar
    Dec 2005
    27
    Default 306 Front Speakers?
    Just wondering if anyone out there can help me out with the positive+ and negative- wires/terminals on the front speakers in the doors of the 306 (1994).
    There seems to be no obvious markings on wires or speaker.
    Alternatively is there an easy way to test using a multimeter?
    2000+ Brad's Avatar
    2,404
    You can't test them with a multimeter, however if one has a stripe on it that will be the negative. In anycase, so long as you wire all speakers the same, then it won't matter.
    Dec 2005
    27
    Thanks Brad.
    Hmmm, only replacing front speakers and headunit at this stage. Fingers crossed for the stripe. Id rather not have front/rear out of phase.
    Are you still driving an S16? Or was that sold?
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,449
    Quote Originally Posted by Brad
    You can test them with a multimeter. The positive lead will read a positive ( approx 6 volts ) voltage with the multimeter earth lead earthed.The negative speaker lead will read approx -6 volts or minus voltage with the multimeter earth lead earthed. Of course you need the radio unit turned on. That's how i figured it out last weekend with the new rear speakers.
    Multimeter = Fluke 21 Series III
    2000+ Brad's Avatar
    2,404
    Hmm, didn't know that trick. I would of though that wouldn't work seeing as the speaker signal is AC. If you are replacing the headunit then you can easily check by seeing what the wires are on the back of the headunit you take out.
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Quote Originally Posted by jackafrica
    That doesn't work with every car/head unit though... you can do that because it a basic flaw in the amp section of most headunits. No big deal, but your taking for granted that the wiring from the factory was ok. When i did car stereos 1 in 5 brand new cars had their polarity wrong to begin with. - Chris
    ... ptui!
