Piston Orientation in Series 3 205 engine?
Results 1 to 7 of 7
    9,548
    Default Piston Orientation in Series 3 205 engine?
    I have noticed that the tops of the pistons in both my Series 3 engines are marked with an arrow and the letters DIST.
    According to the Haines manual the arrows should point towards the camshaft sprocket and this is the way the pistons are fitted to the engine at present.
    I guess "DIST" refers to something else than distributor? Something to do with camshaft timing probably.
    Could be a trap for the unwary.
    Has anyone tried "Gapless" rings in a 205 engine?
    I intend to buy quality rings from Australian Precision Engine Parts, just trying to decide on gapless or not.
    I've had the head rebuilt with new valve guides, a three angle valve job, and a bit of porting, including manifold matching.
    Graham
    Perth Western Australia
    2,712
    Default Pistons..
    Graham
    Graham,
    I have to hurry up, Top Gear is starting.
    "Dist" may be a reference to the inlet side of the engine. "Distribution" ?
    12,283
    Graham
    PRV engines also have this arrow on the piston crowns and they are supposed to face towards the front of the engine
    i just took dist to mean front but my knowledge of french isn't the greatest
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Aug 2005
    Athens, Greece
    661
    Graham
    With apologies, Graham, I have a question instead of an answer: What is manifold matching?
    Thank you
    Thanos
    12,283
    without knowing exactly what he has done i would say he has match ported the manifolds to the ports on the head to have everything flow evenly without restrictions
    1 x 2018 3008
    9,548
    Yes, that's right.
    On the XN "AV" is used to signify front.
    Graham
    Aug 2005
    Athens, Greece
    661
    Yes, that's right.
    Graham
    Great thank you. The machine shop informs me this has already been done with my XN6 head/DCOE manifold.
    Thanos
