Peugeot 205 GTi V8
Results 1 to 23 of 23
    Jan 2005
    Gloucester,UK
    5
    Default Peugeot 205 GTi V8
    Hi guys,
    I've been workin on a little project over the last few months and thought I'd let u see my progress so far!!
    The Engine: -
    Bought for the princely sum of 50 English Pounds!!! Bargian!! And delivered to the workshop for a tenner!!!
    It's a 3.5ltr Rover V8 out of a Range Rover running twin SU carbs at the moment. Just need to get a starter motor from ebay for a few quid and then we can fire her up!!! !!!
    The plan is to first of all measure up the engine bay and look at how much the bulkhead needs relieveing and then make up the front subframe once I've got a gearbox & bellhousing. Once that's done I can then look at mounting the rear axle and connecting the driveline. I'll be using a Ford Atlas axle cause then I can still use the 1.9 gti wheels!! LOL !!
    Here's a pic of the new beasty!!
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN%3AIT&rd=1
    Gearbox: -
    Still in need of a Rover LT77 5-speed gearbox
    Rear Axle: -
    Its from a Ford Capri 2.8i. Its also known as a Ford Atlas axle. Very stiff n sturdy, also the correct width tooo!!! Just need to make some longer wheel studs, n convert the rear drums to discs.
    Here is a link to the online photo album wiv all the pics so far!!
    http://public.fotki.com/puglife/
    Click on the projects folder under albums n you'll see the pics
    Banned orestes's Avatar
    Sunshine Coast
    4,520
    it'll make a good drag racer.
    Jul 2005
    South of Sydney
    25
    hehehe...that'll put some noses out of joint
    Are the authorities going to let you drive that on the street?
    5,312
    Quote Originally Posted by knucklehead
    Yep,
    As long as it passes the MOT or (more stringent) the SVA, you can drive anything over here.
    Fab!
    Mike.
    Jan 2005
    Gloucester,UK
    5
    Icon7
    Im glad you all approve
    I've decided to build it purely for track use as it'd be way too much work to get it though n SVA test!!
    But, it'll be better on track anyway cause it'll be noiser!!!
    Yeah, I can imagine some people won't approve over there!!
    205's are still pretty common over here and everything that can be done has been or with a slight variation on the same theme, so wanted to do something totally nutz!!!
    Hoping to have it ready for French Car Show 2006 on May 28th but will be hard pushed!!
    On a slightly different note, I'm loving all the different smilies!!!!!! !!!!!!!!
    Mucho better than the new ones we got on the PGAC forum!!!!!!!!!!!!
    Sunshine Coast
    4,520
    I would have thought that all that weight up the front would pretty much turn the car into a straight line bullet, and not much else
    al
    al is offline
    1000+ Posts al's Avatar
    Dec 2004
    2,016
    Dude, i saw your progress on the drivers forum recently... Fkn brilliant work! The rover engine is fairly light, (for a V8) and you should be able to turn this thing into a missile.
    With that spaceframe you should be able to make the whole thing work - look at what the bullet roadsters are capible of. (sure their balance isn't that of the standard car, but they are insane!)
    405 Mi16 - Sold - Now back
    205 Mi16
    505 GTi
    16,852
    How much heavier is the rover motor ... It's an all alloy 3.5litre V8 an incarnation of the old Buick motor (also fitted to Valient P76's out here in a bored out version). The cast iron block 2litre probably isn't hugely lighter
    9,562
    Valient P76s
    Graham
    16,852
    Valient P76s
    Graham
    Before my time, but they had the 4.4litre Buick derived bent 8 didn't they ?? An all alloy unit that was a favorite for all sorts of conversions for years
    Jan 2005
    Gloucester,UK
    5
    its not that heavy tbh
    The block isn't much heavier than a XU alloy block
    the rear end is guna have a fair bit of weight over it with the rear end of the spaceframe plus fuel tank, battery, etc.
    The rear axle is guna have a 4 or 5-link with birdcages and panhard rod so traction will be aided
    9,562
    LEYLAND P76. The Valiants had the boat anchor cast iron V8s.
    Graham
    1000+ Posts pgti6's Avatar
    May 2001
    1,670
    Was this the engine that was fitted to the original Greg Park 504 V8?
    Jeff
    Graham
    405 Mi16 2.2 litre race car for sale.
    http://www.aussiefrogs.com/forum/car...-car-sale.html
    https://www.my105.com/ListingDetails...d/518/id/22164
    Lap times- Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205 Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    1075.6 SamR's Avatar
    May 2004
    1,392
    That's a pretty crazy project you've got there. Good luck, and I hope you succeed.
    Any idea what sort of power figure your aiming for, and how much the car might weigh?
    1989 205 Gti - Sold
    "This year, I invested in pumpkins. They've been going up the whole month of October and I got a feeling they're going to peak right around January. Then, bang! That's when I'll cash in." - Homer Simpson
    Jan 2005
    Gloucester,UK
    5
    cheers guys
    not sure on power figure yet as i may supercharge it
    no idea on weight but will try and keep weight down wherever i can
    Dec 2004
    England
    33
    Thats a hell of alot of work for such a low powered engine though..
    Jan 2005
    Gloucester,UK
    5
    yeah i know but i may well upgrade to a 350 chevy once its all running
    9,562
    Quote Originally Posted by pgti6
    Jeff
    Gregs car has got the 3500 Rover V8, the P76 used a 4.4 litre version.
    Graham
    Fellow Frogger! crims's Avatar
    adelaide
    130
    Quote Originally Posted by David Gentleman
    the rover v8 is tough as nails, forged rods and relatively good flow standard, and they rev like no other v8 will, i spin mine to 7500 all day long, and they sound awsome. there is a guy down here that has a tr7 with a turbocharged 3.5 that produces reliable 350 rear wheel kw.
    Fellow Frogger! BigH's Avatar
    Oct 2002
    209
    Some engine weights
    Original Buick 215 V8 318 lbs
    Rover V8 375 lbs
    Chev small block 575 lbs
    Chev big block 690 lbs or only 600 lbs with Alum. heads
    Ford Windsor 289/302 490 lbs
    When they first put a Rover V8 into an MGB they found that it was lighter than the 4 cyl engine that they took out.
    Fellow Frogger! nos205gti's Avatar
    Rozelle
    333
    Icon4
    Quote Originally Posted by uk205mi16
    good luck and take it easy... very big job..but everthing is possible at uk not in australia...but l belive dont spend too much money.. BIG JOB
    Dec 2004
    England
    33
    ..but thats nearly twice the weight and youd have to refabricate all the mounts, new bellhousing (if available) exhaust etc...
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,609
    yeah dont be silly.. stick with working that rover properly.
    as has been seen in many a mini
