Coil packs
Results 1 to 3 of 3
Thread: Coil packs
    9,422
    Default Coil packs
    I have two coilpacks, one Ford, one Bosch (off a 205Si). The Ford has three terminals, the Bosch has four. Why is that? Both are four cylinder.
    Found this:
    http://i1035.photobucket.com/albums/...e_Coilpack.jpg
    Is this info correct? And if it is does that mean I don't need the 25uF external capacitor in this picture:
    http://jtccc.co.uk/index18.gif
    ACHTUNG ALLES LOOKENPEEPERS
    19,485
    Probably the three terminal coil pack has one connection as "common" to both coils.
    Saves a millicent in manufacture
    Fellow Frogger! Molerpa's Avatar
    Jul 2005
    South America, Argentina, That country that looks like hanging from the map... just about to fall...
    492
    the one with the extra wire has the power module inside (+, -, trigger 1, trigger 2) and only receives the order from ECU, but the current, the dwell, everything is controller by its internal module... and the other, the ECU commands it directly (+ common, -coil1, -coil2)
    Quote Originally Posted by luthier View Post
    It is simply impractical to expect a petrol motor to get through too much water. That's why God invented diesels.
