Paint question
Results 1 to 17 of 17
Thread: Paint question
    9,422
    Default Paint question
    What can I use to cover up a scratch that too away the paint but not scratched the metal? It will need a very thin film of filler, but am not sure what next. Do they still have those paint crayons you can use to "paint" dry at the dealers? The car in question is a Toyota, paint is a gun grey metallic.
    ACHTUNG ALLES LOOKENPEEPERS
    It's how I roll...Brisbane
    34,239
    I'd just get a can of matching touch up paint from an autoparts store and spray some into a cup or similar, then using a fine brush build up several layers, enough to level out the scratch and then use 2000grit wet and dry once it has hardened. Good luck
    Every day when I wake up I reach up in the darkness with my eyes shut and if I cannot feel anything that resembles a wooden lid I know it will be a good day. No lid today.
    9,422
    Thank you, very good idea. I think Toyota might actually have the touch up paint. The only problem might be that the scratch is too deep. It looks like the factory used a thick layer of filler or buildup primer. That means I would have to build like the great wall of china in micron paint increments. At a guess, I would say the scratch is about .5mm deep and about 3mm wide, and about 5cm long.
    34,239
    and the problem is...?
    9,422
    Was just wondering if it was possible to build that much with just dabs of paint.
    34,239
    yes it is, it just takes time and attention, but will give the best result this side of a repaint.
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    21,260
    I have brush painted small areas applied thickly (in layers) and sanded away the excess to glass smooth finish. The bigger problem will be colour match if the paint has been sun faded. Less of a problem on white than a strong colour. You will see soon enough.
    My neighbour has used the local scratch and dent guy and was happy with the cost effective solution. Got the colour match spot on for the next few years until the new and the old start fading at differnet rates
    9,422
    Lucky the paint is not faded, the car being quite new. Unlucky it's am metallic colour (dark gun metal grey), not sure if brushing will give it the depth. We'll try and see.
    8,496
    Why not try those guys who advertise bumper/wheel repairs and the like.
    You might be surprised how good a job they do for such a small fee.
    Jo
    9,422
    I am looking into it, Jo.
    Just got a quote for 200 $, and on another line I found that I can get the paint prepared by Toyota in a spray can (300ml) for 29$.
    I am not that confident with my painting skills and it's quite rainy and humid here right now, but for 29$ I would give it a bash. Any advice from more experienced people is welcome.
    Jun 2011
    Brisbane Qld
    21,260
    My limited understanding of metallic paint is it does not like being sanded.
    8,496
    Quote Originally Posted by FIVEDOOR View Post
    Do it once do it right, would seem a good slogan.
    Jo
    34,239
    Shiltzy,
    I wouldn't worry about humidity for what you are doing.
    Naturally you will mask around the scratch so as to contain any drips or dirty finger marks and then start filling the scratch with multiple layers of paint (stirred regularly), this may take a couple of days unless you have access to drying lights. Once the scratch is filled and paint hardened you will carefully block sand it with 2000 grit wet and dry until smooth.
    You will realize that the metallic paint will have a clear coat over top so you will have to do the same process with a can of clear coat because the base coat will not be waterproof (it's not designed that way). Then final buff/polish
    It may sound like a lot of stuffing around but it is a handy skill to have and with practice you can repair big stone chips the same way. Go for it..
    9,422
    Thank you for the encouraging.
    I do have a drying light, very handy little tool.
    Jo, from past threads, my guess is sanding is needed or any paint job to make the surface glass smooth. 2000 grit is always present in my toolbox for other odd jobs, and I can tell you, it can give a mirror finish on any surface, including difficult ones like aluminium or copper.
    Jun 2011
    Brisbane Qld
    21,260
    Re sanding metallic paint. Just google 'sanding metal paint'. I think you will find the advice is dont sand the paint, you mess the metal flakes, some say you can sand the clear, but not the metal flake paint.
    Good luck
    7,568
    14" flat 2nd cut in mine. Far more useful.
    16,853
    Good luck
    You'll trash the metalic pigments. If you can carefully "dust" some correctly coloured base into the scratch, with the metalic pigments spreed evenly. Then it's the clear you would use to fill the scratch and sand....
    Note: i've never tried this .... If my cars get scratched, and least I can prove they have been used and enjoyed
    Shane L
