505 diesel series 2 instrument cluster
Results 1 to 3 of 3
    Fellow Frogger! tomb's Avatar
    209
    Default 505 diesel series 2 instrument cluster
    Had to replace my instrument cluster on the 505 SRDT series 2, same old jaeger story with the odometer going ballistic, got lucky at pick a part and got one from a '87 GTD with only 330th showing on the odometer. Should last for a few more years.
    The top right hand gauge on the the SRDT showed engine oil temp and was powered by a third sender on the base of the oil filter. On the GTD there was only two senders (no oil temp sender) and the gauge on the instrument cluster now operates more like it indicates oil pressure. I have disconnected the wire to the third sender and the gauge still functions, jumping up to the fourth line on start up.
    Did the function of this gauge change between models,
    Tom
    651
    The oil temp gauge doubles as an oil level gauge when the engine not running.
    Sounds like yours might think it's an oil level gauge all the time?
    504 GL Coupe '73 Silver
    407 HDi Sedan '05
    209
    Thanks Uffee, next oil change i will see what it does after i have drained the oil,
    cheers Tom
