Renault Scenic RX4 Gearbox
Results 1 to 2 of 2
    Fellow Frogger! aquinian's Avatar
    WA
    604
    Default Renault Scenic RX4 Gearbox
    Hi All,
    A friend has been told that his 5th gear bearings have failed on his Renault Scenic RX4. He also has been told (not by the gbox mechanic) that they can be replaced with the box still attached to the car - which I was very suprised to hear. Can anyone confirm whether this is true or not please?
    Michael
    Current: 406 Coupe, 504 Sedan
    Previous: 306XSi, 205GTi, 206Gti, 505 V6, 505 Wagon, 504 Sedan, 504 Wagon, 306Gti6, 306XT, 205Si, Citroen XM, Citroen Xantia
    Nov 2002
    Golden Beach, Queensland
    2,763
    I think it maybe possible.
    The 5th gear arrangement can be accessed via an inspection plate.
    Best idea is to call Renault and confirm with them. You won't be locked into using them for any work done, but would be a way to find out for sure.
    I've seen one of these boxes out of a car in pieces but I can't 100% say it is possible to replace the bearings with the box in situe.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
