205 GTi (1993 build) Power steering rack bush
Results 1 to 8 of 8
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,468
    Default 205 GTi (1993 build) Power steering rack bush
    Can anyone confirm that there is a bush in the passenger side end of the power steer rack?
    No bush shows up on parts list drawings that I have found on line.
    I know there is one in the non-power steer rack, I have seen photos.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    9,549
    No, only in the non PAS racks, this goes right back to the 505s as well.
    Graham
    Quote Originally Posted by BIGRR View Post
    Feb 2006
    North Rocks, Sydney
    2,468
    Thanks Graham.
    Mine has a lot of play and I think it is in the housing passenger end. The road wheel moves a couple of mms in the 9 to 3 o'clock direction. The boot has been torn for a while and the car steers a bit (very) queer on bumps and has began to pull right under acceleration. I guess I need a new rack. I think most of the later ones will fit with my tie rod ends connected (?).
    Present fleet:-
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 69' 10
    Renault 71' 10s
    9,549
    Fit an Si rack, only 2.75 turns lock to lock
    Graham
    Thanks Graham.
    NSW
    639
    Have you checked that the rack is actually tight on the crossmember?
    Adrian Wuillemin
    Feb 2006
    North Rocks, Sydney
    2,468
    Adrian,
    have checked, but will double check before I pull it out.
    Present fleet:-
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 69' 10
    Renault 71' 10s
    NSW
    639
    I have a rack in the shed if you want to look at it before removal to see how things work
    Adrian Wuillemin
    Feb 2006
    North Rocks, Sydney
    2,468
    Adrian,
    Will not have to take you up on that.
    I spent a bit of time today (No rain) with some wedges, jacks, chocks and a dial indicator.
    The rack had a bit of play only.
    The play is coming from a stuffed bottom balljoint! Apparently they only last 20 years or 280k km.
    P.S. My rack is 3 turns lock to lock. I don't think I will be swapping to an Si one to save 0.25 of a turn. I don't have enough skin left on my hands and wrists.
    Present fleet:-
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 69' 10
    Renault 71' 10s
