(Sexy) short skirts !!
  • 1 Post By stew
Thread: (Sexy) short skirts !!
    Fellow Frogger! rubyalpine's Avatar
    Christchurch, New Zealand
    497
    Default (Sexy) short skirts !!
    Now that I've got you interested.....
    I've noticed that there are many adverts for high performance pistons with very short cut-away skirts, some just a couple of millimetre below the gudgeon pins.
    Just out of curiosity, I was wondering what the consequences would be if a standard piston was similarly cut away, or alternately, was drilled around the skirt to lighten it!
    Maybe the technical gurus out there can enlighten me, and prevent me from considering doing something stupid.
    Henry
    It's how I roll...Brisbane
    34,239
    Damned! caught again....
    Every day when I wake up I reach up in the darkness with my eyes shut and if I cannot feel anything that resembles a wooden lid I know it will be a good day. No lid today.
    7,568
    A short skirt is lighter and has less friction. However, they will rock more in the bore, increasing bore wear rate.
    Fellow Frogger! stew's Avatar
    Apr 2011
    brisbane
    507
    Not a wise move. Pistons like you describe are for low friction go fast engines. They can be noisy when cold if the machining in the bore is not right. Not a wise choice for street use. As you are aware the piston skirt is not circular and expands with heat to give a close running tolerance. If you lighten the piston then your engine balance goes out and most likely change the expansion shape of the skirt and you must re balance rods and pistons and crank again or the engine gets a vibration. There are better ways to make your engine sweet!.
    PeterT likes this.
    497
    Thanks guys.
    Henry
