205 GTi fuel pump replacement.
Results 1 to 9 of 9
    9,548
    Default 205 GTi fuel pump replacement.
    The fuel pump on my rally car died recently and the spare I bought a few months back turned out to be no good.
    I can get the actual pump locally but how do I pull the holder unit apart to fit it?
    Graham
    9,548
    Turns out this pump is also listed for VL Commodore and heaps of other cars, sounds very unlikely to me.
    NSW
    639
    There are several different pump set ups. Si's are different to GTi models.
    Post a picture and I may have one or show you how to pull it apart.
    Adrian Wuillemin
    9,548
    It is for a GTi.
    I managed to get the bottom filter housing off by being brutal and snapping the retaining ring.
    I have a 505/VL Commodore pump and it may fit although the inlet tube will have to sawn off, the innards of the pump are in full view on the original.
    I need a replacement organised by tomorrow.
    Does anyone have one in Melbourne?
    Graham
    Quote Originally Posted by Adrian Wuillemi View Post
    9,548
    Maybe the clamp on the hose from the internal pump is loose, has anyone had this happen?
    It is for a GTi.
    Graham
    1000+ Posts pgti6's Avatar
    May 2001
    1,670
    Is the 405 pump the same? Bosch part no-0580 464 038. Pretty sure when I checked that number it was the same as Commodore/505.
    I have a spare working one & mounting bracket here I can lend you.
    405 Mi16 2.2 litre race car for sale.
    http://www.aussiefrogs.com/forum/car...-car-sale.html
    https://www.my105.com/ListingDetails...d/518/id/22164
    Lap times- Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205 Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,468
    Graham,
    have a look at a post by me on 19/10/11- "Smelly 205 fuel pump" it may be of assistance, it has been working for me for 5 years or so.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    9,548
    I have a 505 one, these are mounted by themselves as is the 405 I think?
    The 205 has it mounted in a plastic cage which is inserted into the tank.
    The fuel pressure is low but you can hear a noise from the pump/tank just after the pump is switched off, good chance it is fuel leaking past the hose connection.
    Big RR I'll take a look at your postings.
    Graham
    Quote Originally Posted by pgti6 View Post
    9,548
    Fixed, the replacement pump had a torn rubber hose but the old one was OK and I managed to fit the 505 pump. I opened up the bottom end of the pump with a hacksaw as per the original and this also made it short enough to fit. Hopefully the filter sleeve is sitting in about the right spot, as mentioned above I had to split it to get it off. The 505 pump does have a filter in its base as well. All a bit untidy so I would be happy to get another good complete pump.
    Thanks for the advice.
    Graham
    Graham
