Why fan switches die
    9,421
    Default Why fan switches die
    I have experienced recently a number of failures of the fan thermoswitch even though I had it replaced with the correct new part every time. When I got bored of replacing the buggers I just hardwired the contacts on so the fans run all the time when the engine is on (this is a 205GTI we're talking about).
    And then one day, I grabbed one of the failed switches and opened it on a lathe carefully turning off the bronze lip that holds the plastic end on the sensor head. Inside, I found signs of water ingress and the contacts were corroded. I looked at everything and found there is a rubber seal running at the base of the plastic bit, under the lip. This seal seems to have failed and allowed water to creep inside, invade the switch and do its nefarious business on the contacts. Everything else was fine. Stupid crappy sender units and their retarted seals and lips. Made in Spain, probably during the siesta. I suppose next time I'll buy one of these I'll run a bead of RTV silicone around the lip just to make sure.
    Anyway, hope this might help someone.
    ACHTUNG ALLES LOOKENPEEPERS
    Feb 2013
    israel
    822
    the girl that i love will be made in spain, and why not?
    Jul 2012
    15
    Thanks for the tip schlitzaugen.
    I like the small but handy investigatory insight you shared with us.
    In fact also to all those who regularly share their experience n knowledge.
    Where is this fan switch located - at the fan housing or near the engine thermostat?
    I've yet to invest in a workshop manual.
    9,421
    Just on the RH side of the radiator about halfway down. Has three wires going to it.
    9,421
    Quote Originally Posted by 2pac View Post
    As long as there's nothing wrong with her lips or seals, I'd say go for it.
