Dfz Dkz Engine combination
Results 1 to 3 of 3
    81
    Default Dfz Dkz Engine combination
    Hi all
    I know I've read about using a dfz block and pistons with the dkz head for higher compression. Just wondering what actually produces the higher compression? I would ideally like to use the dkz engine as it has less kms and rebuild it using dfz pistons if this is possible? I know I could look up all the dimensions and I will but I'm just wondering at this stage.
    Via the aussiefrogs App
    1000+ Posts Dave's Avatar
    Apr 2001
    1,339
    Yep the pistons on the DFZ have less dish. The combustion chamber on the DKZ is smaller. The piston is the only thing on the DFZ that you are really needng the bottom end for, so your plan seems ok to me.
    Dave
    81
    Thanks Dave.
    So my plans are to basically use all of the DKZ however use the DFZ pistons.
