any advice on 405 m16 to twin carbs conversion
Results 1 to 20 of 20
    May 2012
    uk
    13
    Default any advice on 405 m16 to twin carbs conversion
    hi , just wondering if its worth fitting carbs (twin 45,s) to my car, and how to wire, plum in fuel, ignition etc. ive got all the parts.(i think)
    any advice would be helpful !!!!
    thanks
    7,568
    Nope, don't do it.
    May 2012
    uk
    13
    thanks for reply, reasons why ?...
    Far North Queensland
    1,494
    As an alternative upgrade, Peter what are your thoughts on fitting a throttle body from a 2.8 V6 as per this article?
    http://www.205gtidrivers.com/article...on-on-mi16-r29
    Would this comprimise low speed tractability too much?
    Paul.
    May 2012
    uk
    13
    what about throttle bodies? or is better to leave alone?
    could do with a bit more bottom end power......
    Dec 2002
    Menzies Creek
    2,569
    Quote Originally Posted by 504-504-504 View Post
    Paul.
    I did this exact modification in 2001 to my Mi16.
    I noticed no difference in power, but the throttle became much less progressive, and had more of an 'on/off' feel. I wouldn't do it again. Uncomfortable to drive sedately.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    1000+ Posts Richard W's Avatar
    May 2012
    1,383
    Does the MI16x4 have the 1.9 that was detuned for Aussie fuel. If so, would the logical start point be PeterT's suggested mods to raise compression and maybe a mild cam?
    1,494
    Quote Originally Posted by Demannu View Post
    Thanks Scotty, don't want to compromise roadability, good advice.
    Paul.
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,470
    Yes. Fitting throttle bodies is more the way to go. Carbs are a step backwards.
    To do it properly will cost the best part of 2000 Pounds. Otherwise, get a set of PeterTs stage 1 inlet cams and play with that. Will liven it up nicely.
    Rick. Being a european car, the MI16 will have the higher compression already.
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    May 2012
    1,383
    The joy of Tapatalk - I didn't see that the car was in the UK!
    Nov 2003
    Bondi
    3,470
    Haha! Yea. And I called you Rick!
    CHeers for the Bumper Rich, got it yesterday. Will go nicely on the current car. The garage is a disaster. After getting rid of the Xsara its loaded with parts of all sorts! Ill be working on it most of the week if you fancy popping over for a proper look.
    You thinking of going on the Drive to the Hunter?
    Cam
    91 205 Si
    87 205 GTi Race Car
    7,568
    Carbs on an Mi16x4? Even on an Mi16 it's sort of pointless. For example, what will you do for ignition? You either have to fit a distributor or aftermarket mapped ignition. In which case, you may as well spend a little more and fit a full fuel/ignition ecu.
    May 2012
    1,383
    Cam
    Haven't decided yet. If there was a group going up via a good route I would be keen.
    Fellow Frogger! callipygous's Avatar
    Jan 2006
    Toowoomba
    798
    My advice is to check out www.boggbros.co.uk
    If you've decided against carbs go on ebay and search 'yamaha r1 throttle bodies'.
    May 2012
    uk
    13
    thanks for advice, i was only thinking about it, cos i have the set up up outta a 205 mi16! on carbs
    which includes
    twin 45 dhla dellortos + manifold
    dizzy conversion
    fuel regulator
    fuel pipes
    205 loom
    everything out of a 205 mi16 on carbs....
    regards tb,s or r1, is that easier to do?
    May 2012
    uk
    13
    any ideas what a carb conversions worth for a 205 mi16??
    1,389
    Convert the carbs to throttle bodies. Lots about it on the net.
    Jan 2006
    Toowoomba
    798
    Why Have Webers when you have a choice of either throttle bodies or Mikuni carbs?
    May 2012
    uk
    13
    thanks for advice, guess webers not the way to go....
    so regards throttle bodies/ bike carbs, do they bolt straight on ?
    just wondering on ecu,s, fuel pressure etc........?
    ive got a weber inlet manifold (if it helps)
    Jan 2006
    Toowoomba
    798
    You'd need an inlet manifod made up for bike throttle bodies/carbs. Bogg Bros make these for a very reasonable price, just email them for a quote. They're very helpful.
    For carbs you'd need a fuel pressure regulator.
