knock sensor for Jaycar kit KC5444
    9,422
    Default knock sensor for Jaycar kit KC5444
    Does anyone have any idea what knock sensor I can use with the KC5444 kit from Jaycar?
    ACHTUNG ALLES LOOKENPEEPERS
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    DOes anyone have any idea what knock sensor I can use with the KC5444 kit from Jaycar?
    Below is a PDF for the full instructions
    I think its the same as your kit.
    If so, it appears that pretty much any early Knock Sensor will do the job.
    http://www.google.com.au/url?sa=t&rc...45960087,d.dGI
    9,422
    Yep, that's it. Thank you monsieurenault, but I have no idea where to start looking for a knock sensor or what "early" means in this case. What cars had "early" knock sensors?
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Based on the wiring diagram, any 2 wire (earth and signal should do the job) knock sensor should do the job. I think the are all 5v much like TPS and other sensors in the efi system.
