Wiring help XU10J4R Coils running wasted spark
Results 1 to 25 of 47
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,470
    Default Wiring help XU10J4R Coils running wasted spark
    Im hooking these up to a haltech. I need to first figure out which pin number on the coil cover corresponds to which coil.
    There is a 4 pin plug that runs into a sealed cover that houses the coils. Im not sure if I can test it with a meter as coils retain charge?
    Pics to follow
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Nov 2003
    Bondi
    3,470
    Wiring help XU10J4R Coils running wasted spark-coils-1.jpgWiring help XU10J4R Coils running wasted spark-coils-2.jpg
    91 205 Si
    87 205 GTi Race Car
    NSW
    639
    You need Peter
    He has them running on robert riggs car.
    Think it will come down to you having the correct ignitor
    Adrian Wuillemin
    Nov 2003
    Bondi
    3,470
    Only reason I ask is Im going to be running a mates Haltech from his GTi6 and swapping it to may car and I dont want to have to put it on the Dyno etc. Im opening my business next week and have zero cash! Hopefully peter will see this and shed some light.
    Otherwise, am I able to use a multimeter or will i get shock!?
    Thanks for the reply
    Cam
    91 205 Si
    87 205 GTi Race Car
    7,568
    Sorry, can't find the data. What I do know however, is that one wire is +12V, another is cylinders 1 and 4, another is cylinders 2 and 3, and the fourth is for the capacitor/suppressor. The first and the last will be zero ohms. Ask on the 205 forum. That's where I found it.
    Your bigger issue is how to fire them. You will either need two ignition modules or a dual channel CDI/MSD etc. You can't fire them directly from a Haltech ECU, as it won't be able to handle the current. The easiest setup is two '008 ignitors (or equivalent) and set the Haltech output to constant duty. The cheapest setup is two 205/405 ignitors and set the output to constant charge, but you'll need an oscilliscope to optimise the charge time. The best setup is to buy an M&W dual channel CDI.
    Nov 2003
    Bondi
    3,470
    Would it be easier to buy 2 more coils and run them from the ecu?
    Are they the same as a GTi6 Coil? Find 4 of them and run them form the Haltech?
    Cam
    91 205 Si
    87 205 GTi Race Car
    Newcastle
    2,879
    Hi,
    Peter will most likely have the answer. However it is quite safe to use a multimeter on the coils. There will be no shocks.
    Cheers Jaahn
    Nov 2003
    Bondi
    3,470
    91 205 Si
    87 205 GTi Race Car
    7,568
    The only coils you can run direct from the ECU are LS1/LS2 with built in ignitors. This could be a false economy for you however, as you will still need some custom ignition leads, ~$100. GTi6 coils are individual (direct fire) and do not have built-in ignitors. Yes, the Pro-12 is a solution.
    You can bench test the coils to work out the wiring. I'm fairly sure the +12V wire will be the largest.
    Nov 2003
    Bondi
    3,470
    Ok thanks for the info. Makes sense.
    When you say the Pro 12 is a solution, is that the easiest way to go about it or is another unit better suited?
    Cam
    91 205 Si
    87 205 GTi Race Car
    Nov 2003
    Bondi
    3,470
    Or something like this peter? Get some HT leads and a harness made up and go from there?
    http://www.ebay.com.au/itm/LS1-Coil-...#ht_1229wt_956
    Cam
    91 205 Si
    87 205 GTi Race Car
    Fellow Frogger! patpug's Avatar
    614
    Haltech dual channel ignitor $170 or $90 for those LS1 coils + custom leads... http://store.haltech.com/default/ign...and-paste.html
    In the long run you'll be better off with the LS 1s, you'll use them on your stroker engine too. But don't forget about having to custom build a bracket for them. I have a white line strut brace that you could hang them off!
    205 gti-6
    205 track car build in progress http://www.aussiefrogs.com/forum/res...-race-car.html
    9,554
    Coils don't retain charge, capacitors do this.
    I guess just connect a 1.5 volts battery to the primaries and see what happens at the secondaries (using a meter) as the primary is connected and disconnected.
    Graham
    Pics to follow
    7,568
    BIGRR runs a dual channel MSD on his XU10J4R and it's one of the sweetest sounding engines you'll ever hear. That's why I suggested the CDI. I run the Pro-14 on my 205. You just have to weigh up the cost/time of fitting aftermarket coils versus the CDI price. As Pat suggested, the Haltech dual channel ignitor is also a good option in terms of price, but you'll still need to optimise the charge time with an oscilliscope.
    614
    Is the point of the CDI that it automatically works out / optimises the charge time so there's no need for the oscilliscope? Also, do you think this (with the j4r coils) woud be a good option in the future for the bigger hp engine that Cam's building too?
    205 gti-6
    Nov 2003
    Bondi
    3,470
    Peter. Can u let me know which MSD it is the RR uses. I'll order one over the weekend and run it that way. It seems to be the easiest option with the best result. I've had a look at a few but am unsure which to get for my application.
    Cam
    91 205 Si
    87 205 GTi Race Car
    614
    Cam, just realised that you need an air temp sensor too... This harness has the plug for the sensor from haltech, its on their online store.
    205 gti-6
    7,568
    MC-1 for motorcycles, although I'm not sure they make it any more.
    Nov 2003
    Bondi
    3,470
    I think its going to be cheaper to run the LS1 coils and make a bracket to mout them. I have Pat bracket the Owen made I can copy to munt the coils. At 90$ for a set of four second hand I think I would be silly not to. I need to have my car on the road asap and also need to keep any unwanted cost down. I would love to do it perfectly and fit a CDI or MSD but at 400$++ I just cant justify it at the moment.
    I was also going to try and fit Sequential injection but there is no bung hole for the Cam sensor so will also have to give that a miss at the moment.
    Thoughts?
    Cam
    91 205 Si
    87 205 GTi Race Car
    7,568
    I'd probably just buy a dual channel ignitor. Heaps less aggro.
    Nov 2003
    Bondi
    3,470
    Ok. Im struggling to find one to suit my application. Can you point me in the right direction?
    Cam
    91 205 Si
    87 205 GTi Race Car
    Nov 2003
    Bondi
    3,470
    And Ill need and oscilloscope? Whatever they look like or do? Only info I can find is that they use them in hospitals? Which one will I need along with the dual channel ignitor?
    Cam
    91 205 Si
    87 205 GTi Race Car
    614
    Oscilloscope is a tuning tool that is used to measure the pattern of the charging and firing of the coils (amongst other things) when using separate ignitor to charge the coils up. That's the beauty of the LS1s, built in ignitor means that all of that has been worked out already.
    Id be interested to hear what Peter means by too 'agro' though... Is the CDI much smoother? My car is a bit of a grumpy beast :-D
    205 gti-6
    Nov 2003
    Bondi
    3,470
    Only reason Im keen to use the Dual channel is that I dont have to have a mount made for the LS1 coils. Its seems it will be easier to sort the problem. And I like the sound of having a good sounding car!
    FWIW Pete, Im going to be using a GTi6 Inlet and Exhaust on the car so will be interesting to see how it runs with the J4R
    Cam
    91 205 Si
    87 205 GTi Race Car
    614
    Id be more concerned dollars wise about paying a tuner to work out the charge time than getting a mount made up, but I might be wrong about that...
    205 gti-6
