Grout filling wet sleeve engine.
Results 1 to 13 of 13
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Default Grout filling wet sleeve engine.
    Has anyone had any experience with grout filling an engine?
    http://www.hardblok.com/product-info/
    Been considering trying this to a Dourvin engine to increase block rigidity so I can run higher boost.
    I have an old 2.0 from a Fuego that I could try it on, so I was going to fit a new set of liners and then half fill the water jacket with grout and clamp the head down until it sets.
    It would make the sleeves a solid part of the block as you can't remove it once set, so it would make it a throw away if anything destroyed a bore but It would make the block a lot stronger.
    Anyone heard of it done to a wet sleeve engine?
    Gone Fishin' Haakon's Avatar
    May 2002
    canberra...
    8,898
    Flip, how many horses are you chasing...?
    Considering the R21T boys in the UK have managed 500hp with monster boost, I reckon the block/liners are up to the task as is.
    Interesting idea though.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    That's the thing about chasing horses, you are always chasing them...
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    21,251
    Very interesting. Wonder if it cold be used to fill small corrosion damage near the sleeve seat on aluminium block?
    3,682
    It also raises the question. What are you going to do with all those horses once you have caught them
    .2010 Holden Commodore Ute
    8,496
    After a higher powered mod like that, how would you measure crank and lower end life?? Revolutions, hours ,days ,weeks maybe...
    If you look at the sump braced 12v motor, it has quite an amount of bracing and oil control, and I'm guessing you'd be exceeding those OE torque specs considerably.
    What do the turbo meth guys do in their speedway cars, or is that sort of not relevant to a street car?
    jo
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Not sure what you mean by 'lower end life'?
    You are filling only the bottom inch or two so the cooling is still adequate. It just stiffens the block alot. The problem with open deck wet sleeve engine seems to be distortion of the liners in the block at high power/torque levels. I don't know how susceptible the Dourvin is as they made a fairly indestructible turbo diesel version with the same basic block.
    I've had no dramas at the current boost/power level but I was interested if anyone had actually tried grouting in the liners on a wet sleeve block as it may be a solution if issues crop up?
    Oct 2002
    Melbourne Victoria
    13,080
    I think I could donate an engine for the project if you decide to go ahead!!
    Perth Western Australia
    2,712
    I recall seeing a story in a Race Preparation magazine.
    It showed a Porsche block with the cylinders [liners?] and block drilled vertically in 3 or 4 places then tapped and screws [scotch locking ?] fitted flush with the block and liner. I presume that this had the effect of wedging the liner preventing movement?
    The turbocharged N engine in the 505 and its other derivatives seemed reliable in extreme competition.
    Interesting theory Mr Grout oops! Mistareno.
    8,496
    Quote Originally Posted by mistareno View Post
    I meant the life of the lower end of the donk....crank, bearing caps, bearings.
    Things that might be attached to this....
    Attached Thumbnails Attached Thumbnails Grout filling wet sleeve engine.-screen-shot-2013-05-05-12.42.24-am.jpg
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    they are doing the same thing pretty much. The grout stiffens the block by adding a mass of stiff substance that bonds to the block to prevent the block twisting. The 21 t has a sump brace that does the same thing by bracing the bottom of the sump and interlinking everything together to form a stiffer block.
    Aug 2012
    korumburra,vic,australia
    151
    Hi there ,my friend who runs a reno motor similar to 2.2 peug
    . motor in speedway,is running 25 lb boost,motor as far as block ,bottom end rods etc are all standard,only real mod is, sleeves have been o ringed,motor runs 8000.
    cheers bob.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,468
    Would there be any problems cooling this grout filled motor?
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
