Wheel toe check.
Results 1 to 19 of 19
    Newcastle
    2,881
    Default Wheel toe check.
    Hi
    Am interested in a simpler way to do my toe-in check.
    Anyone used these;
    Trakrite Wheel Alignment Gauge for cars vans light commercials
    Gunson G4008
    I have not found a alignment shop that will actually do a satisfactory job. I guess tire shops have a vested interest in poor wheel alignment I usually do it my self with a tape but thought this unit would be good to give a quick check. Tires can dissappear while you are thinking about it.
    Jaahn
    Perth Western Australia
    2,712
    Geez, Jaahny,
    "Vested interest ?"
    You'd be a hard man to satisfy. Reminds me of a customer who returned after an alignment complaining that the rubber hadn't grown back on his tyres !
    16,858
    For normal cars I'm sure your local tires places would be fine. You can see the toe-in quite easily if that is all your after just by measuring (infact we even used an extendable tent pole years ago... the idea is you get the wheels to measure the identical amount first..... ie: 0.00mm toe in/out. Then screw each adjuster in 1mm so you end up with an overall toe-in of 2mm (1mm each side).
    Having said that I bought a 4wheel computer aligner cheaply quite some time back so i could fiddle with CX front ends..................... Last night I tried to use it on my ID19 and found the rear wheel hangers can't handle the "D"............. You see the rear track is so much narrower than the front track, the lines that run forward to the front heads can't be adjusted out far enough ................. I'm going to have to have to make up some "long" line holders for the rear wheels :roflmoa:
    Shane l.
    Newcastle
    2,881
    Default Hard to please
    Geez, Jaahny,
    "Vested interest ?"
    Hi Yea
    I am hard to please. What I ask for is a normal quality professional job. What I have received for the last three wheel alignments that I had done when I fitted a new set of tires was shit.
    When the tires soon started to feather I checked the toe myself and had to correct it by significent amounts. The printouts from the u-bute machine showed it was perfect. U figure what the problem is.
    I can copy the printout from last week done on my VW transporter. The toe in on the two back wheels are 1.3mm and 3.3mm total 4.6mm. "within specs". did not get adjusted even though I had specificaally asked for it. "probably could not get it any better anyway", I was told. That place came recommended as the best in town
    Fussy ???? My new tires on the line, $600+ worth.
    I did not ask how to measure the toe, I know how. I asked if anyone had any experience with that Trackrite guage.
    jaahn
    16,858
    They dont' set them up properly .... It's a simple as that. The machine I bought was apparently still being used ... and all bits were there. I tell you it simply defies belief. There is two very minor bits missing.......................... That I can easily make. Without them it'll do a very consitant hugely incorrect alignment every time without fail. Yes it will print pretty little sheets and display the exact figures you have dialed in ........................ Only they'll be the wrong figures
    I just googled your wheel aligner above.... There doesn't seem to be any reviews about on them at all............ Do you really just drive over it like the UTube clip shows I'm scratching my head wondering how that possibly works accurately, but I guess it must
    I much prefer this one ... tape measures can't lie ...and you get an elegant way to clip onto the wheels......... I also understand how it works.
    http://www.ebay.com.au/itm/DIY-WHEEL...30b0b5a&_uhb=1
    seeya
    Shane l.
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,427
    I have never used anything but a tape measure on a DS and never had problems.
    On many cars, toe-in (or out) varies according to how high the car sits on its suspension. You (or the garage) might want to move it through its suspension travel by hand and see what that does to the toe-in. I was shown this by Mick Devaney, the best wheel alignment person in Bendigo, on my XM a few years ago. It was scary!
    Roger
    8,496
    Roger
    Did he fix it for you???
    Jo
    16,858
    Jo
    No .... proper DS/CX/GS/SM suspension will not fit under an XM sadly
    Warrnambool
    2,427
    Shane is right. It's an artefact of the crappy Macpherson strut front suspension. A DS has proper suspension, so you can set the toe-in accurately with a tape measure.
    Roger
    7,569
    I use a U shaped device fabricated from 25 x 10 mild steel flat bar and a rule. The U shaped device fits around the outside of the wheels/tyres allowing me to measure the difference between 3 o'clock and 9 o'clock. I measure off the rim rather than the tyre. Simple. For road 205/405 I use -1 to 0mm, for track cars 0 to +1mm. Under brakes the wheels toe out changing the measurement.
    Newcastle
    2,881
    Default Some reading on side slip!
    Hi
    Side slip testers are used widely OS. But seem to be unknown here.
    Some reading for those interested.
    http://www.paintandpanel.com.au/file...Ealignment.pdf
    http://skyjuiceiswater.blogspot.com....side-slip.html
    http://www.ariestools.com.sg/SST48%20Instructions.pdf
    jaahn
    16,858
    I wouldn't bother with any of that modern chinese looking junk stuff...... Watch ebay .... even if it takes a couple of years and grab a proper old alignment system. I was searching for one like Jo's .... No electronic, just simple anglular measurements and calibrated attachments (ie: it will always, always work 100% accurately and never break ............................................. if you can figure out how the hell to setup the thing ).
    I found this one in the end ...... It was only $100 from memory with the heavy duty turntables and everything, so worth a punt:
    http://www.aussiefrogs.com/forum/sho...=1#post1159600
    seems to work really well. The only problem I've had is trying to convert in my head the "angular" measurement it display versus mm toe in/toe out every manual suplies. Angle is a much more accurate measurement that'll work for all wheel sizes and types.... if only I could find a conversion chart to go from angles to toe-out versus wheel size
    These old units are really cheap as there old for starters, they required detailed knowledge usually to operate and there slow and fiddly to setup and calibrate ................ ie: no good for the average tire changer to use.... However being ex-industrial will be well made and last a lifetime or two.
    This one would be great, but they want crazy money for it
    http://www.ebay.com.au/itm/Holden-Wh...479efa8&_uhb=1
    ShaneL.
    651
    A good rule of thumb is 1 degree is 1 in 57.
    504 GL Coupe '73 Silver
    407 HDi Sedan '05
    16,858
    Quote Originally Posted by Uffee View Post
    Um, Ok 1 in 57 what ?
    651
    So a 15in rim has a radius of 190.5 mm. If we want 1 degree toe, then we'll need 190.5 /57 = 3.34mm of toe.
    Perhaps more useful, if we want 1mm toe, then we'll need 57/190.5 = 0.299 degrees toe.
    Edit: I should note that 1:57 is a rule of thumb, it's suitable for this kind of thing but I wouldn't use it for anything over 5 degrees.
    407 HDi Sedan '05
    16,858
    that makes sense
    Newcastle
    2,881
    Default Gunsens Trackrite Chinese !!!!!!
    ShaneL.
    Well what an insult to the poms. The Gunsens Trackrite is a British unit and has been made for quite a while. So I guess it fails your description on both counts. It also has no electronics.
    Gunsens have been producing innovative tools for the DIY persons to work on their cars for as long as I have been working on cars. However I have not actually seen or used this one in the flesh. Hence the question. Obviously no one else here has either. I will probably just go for it.
    The reason I will not be getting a full old style aligner is simply that I do not wish to get down and do it any more. I have been doing it for years but feel its the end of that stuff. My knees tell me so So I thought if I could just drive over the Trackrite and get a 2 minute answer as to whether I need to have it done or not, I would be happy. If the car drives OK generally then the toe is the most important factor in tire life. If I get my VW correct then the tires will see out my use of it. The recent 'alignment' did not achieve that for sure. Just hard to satisfy, as Wildebeast said.
    jaahn
    P.S. 1 in 57 is a ratio, as is an angle. Could be 1 mile in 57 miles. More to the point here is say; 1 mm in a length of 57 mm as Uffee has shown.
    Last edited by jaahn; 30th April 2013 at 03:31 PM. Reason: Hard to get it right ??
    16,858
    I'd be most surprised if there not made in china Regardless, it looks like you get to be the reviewer if you buy one. I couldn't find a review about them anywhere (you found the youtube clip too ?).
    7,569
    Here's my toe out gauge hanging up in the shed. Hope you like it. It's difficult to see, but it has a pointer on one end and a mount for a rule on the other. Extremely accurate..........well, as good as you can measure.
