Oscilloscope for dummies
Results 1 to 19 of 19
    8,496
    Default Oscilloscope for dummies
    Ever since I was a little kid oscilloscopes have fascinated me.
    B grade sci-fi, Dr Who and all that sci-fi series stuff I grew up on always had a scope display of one type or another slip into each episode.
    I probably should have bought one years ago when i worked in audio, but it was just one of those tools i put on the back burner, plus moving into digital, my gear either worked or it didn't and nearly all the time it did, so I never really found the pressing need for one.
    I'm now at the point where I want to learn up on ignition systems and make some changes to my car, and the time seems right to get a 'scope.
    The problem is I dont really understand the differences between all the products on the market, nor understand the basic kit required to diagnose things around the engine bay.
    My primary aim at this stage is to monitor the ignition as I suspect there are some miss fires at idle but can not be sure.
    Would anyone have any tips on what would be a good basic kit and what leads/probes would be required.
    Whilst I have no idea what type of budget should be set, was hoping to spend up to about $300.
    Am I dreaming on that budget or can a useful tool be bought for that type of cash??
    Cheers, Jo
    9,414
    I think you are kinda dreaming. Jaycar and others like that had until recently some tube scopes (made in China, of course) up to about 20MHz for about that kind of money. When I went to buy one, they said it was discontinued (some months ago). That would have been more than overkill for ignition. Dual trace (I think). Not that you need it. If you can find one lying about in some god forsaken store, grab it.
    These days it's all handheld and it starts above that (I think the cheapest I have seen is about 600$), and I am not sure how good they are in terms of responsiveness of the screen being LCD or some such.
    http://www.jaycar.com.au/productResu...2&keyform=CAT2
    There you, wrong again.
    PS. You're not thinking of hooking it up to the spark plug wires, are you?
    ACHTUNG ALLES LOOKENPEEPERS
    bob
    bob is offline
    May 2001
    Skipton
    2,579
    G'day Jo,
    there are a few old references here that I could scan a few pages for you. Your HT pickup is just a clip on detector, like you get with a timing light. Or, I seem to recall from eons ago when I had an old war surplus unit that did that job, a small bulldog clip
    Never even thought about the waveform for modern vehicles, you'll be able to write the new texts
    References here that might be around in http://used.addall.com/Used/ -
    Wanniger - Using electronic testers for car tune-up
    Evenson - Automotive test equipment you can build
    Lytel - Automotive electronics test equipment
    amongst others probably !
    these days a poke around at http://www.archive.org/index.php might even turn up PDFs !
    cheers,
    Bob
    19,465
    Virtually any oscilloscope will do the job of the display. The frequency, nature of the signal and voltage levels involved are modest.
    Engine pick ups are likely to be the hardest parts, but if you are handy electronically they can be built. Being mainly resistive divider and inductive pick ups.
    FWIW I would not consider a CRO (cathode ray oscilloscope) unless it was very very cheap.
    Modern units like this (note the small size) give good bang for buck. Being ground isolated is an advantage.
    http://www.ebay.com.au/itm/AU-STOCK-...ht_3883wt_1193
    You need to check if probes are included, because they can cost quite a few dollars.
    What you are really looking for is an old vane engine analyser. This is custom designed for the purpose, with all the probes, vacuum measuring gear etc. But I guess they are worth a bomb and like hen's teeth.
    The advantage of the Vane gear is the how to use book that shows expected wave forms.
    EDIT: I have two scopes. The old Telequipment CRO and later Tektronic DSO.
    I haven't used the former for 15 years or more. It developed a "off horizontal" trace issue but works fine in both channels other that that (as I remenber)
    The telequipment scope is yours for the asking. I'm never likely to use it again since I have the Tek DSO now. The Telequipment has no probes, but you will be making something I would assume.
    PS
    It's a museum piece now! I purchased it in the 1970s to further my Electronics Hobby. So you will be taking a piece of test equipment history if you want it.
    Attached Thumbnails Attached Thumbnails Oscilloscope for dummies-cro.jpg   Oscilloscope for dummies-tek.jpg
    con
    con is offline
    sydney, nsw, australia
    526
    Cheers, Jo
    I have one of these. Works well.
    https://www.sparkfun.com/products/10244
    con...
    8,496
    PS
    Wow, Rob thats a very generous offer on top of you usual good advice.
    I had a chuckle at the vane suggestion though, my engine management and other bits and pieces are 20 years ahead of that technology.
    Digging holes in the ground today gave me plenty of time to give this proposed acquisition some more thought, and it occured to me that a bench unit is no good when your garage is so full of shit that the car wont be able to get within 20 foot of it.
    For that reason, and the fact that I live 1000km from you, I will pass on your offer for now. Thank you all the same.
    That leaves the little mobile phone sized ones or a PC units as being more suitable for my needs
    Yesterday I pulled a figure out of the air...$300, and found this little unit today on the net which fits just into that budget (less leads).
    http://www.bitscope.com/product/BS10/
    Hardware/software does not phase me either way, but the portability seems like a bonus and the fact that it can be used on a mac or a PC also suits my needs.
    It is not only made in australia, but locally to me in st leanards, which gives me a warm fuzzy feeling that if I spend the dollars, they are staying in my local community.
    Also handy when I fry it and need it serviced.
    Any thought on that unit??
    Jo
    19,465
    Jo
    Have a chuckle with me too, I had in my minds Bob created the post, when i offered the old scope as a giveaway.
    Later on it dawned on me that shipping four "house bricks" to NSW would be impractical.
    The unit you have is chosen is real overkill for you needs. The $100 suggested by Con or the $68 cheapie from (if it works and arrives) would be fine.
    But.. you always "grow" into test gear. Immediately you "get a picture" of what is happening diagnoses of problems are easier.
    When you get it, make a habit of connecting to everything, audio stuff, digital stuff, the door bell etc etc to get a feeling for what is normal and to become proficient at the controls, Knowing the instrument is essential to use it as tool. This is more so for yourself because are a learner from school of hard knocks and not from book learning.
    This is not meant as a negative. Some of most qualified engineers are morons practically and couldn't make a globe light off the battery.
    However some amateur radio operators would leave most engineers for dead because they have learnt from hands on and picked up the theory afterwards.
    Learning to use and interpret a DSO will be steep learning curve, but you will be up to it.
    If the $300 is no problems by all means buy local. You will have somewhere to take if it doesn't work or you have questions. It is probably miles better than a cheapie anyway.
    One word of warning. Many of these "pico scopes" will not tolerate mains voltages due insulation ratings of the pcb and the component ratings. You should check this manufacturer. For my money I would not go near 240vac mains or switch mode power supplies.
    bob
    bob is offline
    May 2001
    Skipton
    2,579
    G'day Jo,
    I see that those references I gave above are available on line for very little - I can scan the relevant pages though if you like ?
    Bit of googling provides....
    http://bmw.workshop-manuals.com/3_Se...dex.php?id=508
    through to....
    http://bmw.workshop-manuals.com/3_Se...dex.php?id=510
    for modern systems. Look pretty much like the olden-time pix I think, but the oldies are going to show point/condenser problems etc, are these display symptoms appropriate for modern systems ? could be a whole new ball game ?
    cheers,
    Bob
    8,496
    Quote Originally Posted by bob View Post
    G'day Jo,
    cheers,
    Bob
    Dwell is still dwell, (and misfire is still misfire) but my engine uses electronic control of it by the bosch 008 (smart) modules, and is not adjustable.
    At best i can simply observe the result. I still want to do that though because whoever designed my ignition system took the unconventional route of ganging two coils of the one ignition module to get the wasted spark, as opposed to using a single coil with dual post output.
    I will be adding knock controll soon and would like to observe aspects of the knock sensor signal, the controller's modifications and the end result to the engine.
    Jo
    8,496
    Looking stuff up on the net and have come across some good info.
    I'll post some here.
    An oldie but a goodie....
    http://books.google.com.au/books?id=...20test&f=false
    5,685
    A simple strob timing light will show misfire (not as well as a scope, especially one that stores info)
    "The enemy of knowledge is not ignorance, it's the illusion of knowledge"
    Stephen Hawking
    Feb 2011
    Brunswick Heads NSW
    95
    I recognise that PM cover as one that's been hanging around at our house for the last umpteen years....
    8,496
    Quote Originally Posted by frankthezapper View Post
    Its pretty cool retro. Love the skivvies and beige.
    Jo
    1,389
    BitScope is good - I have seem it in action, albeit in use with a spectrum analyzer. Plugged into a good lap top you will have a good portable tool.
    I have a Goldstar 20mhz dual trace scope 'cause it's the devil I know! If i'm trying to read anything that this scope won't do, them I find myself way out of the electronics ball park.
    Moo
    8,496
    Being unable to edit my posts makes the concept of linking good resource sites tedious, but until something is sorted (or unless a moderator wants to wipe my bum for me and move this link to post #10 and delete my whinge) here is another great link explaining probes.
    http://www.ece.vt.edu/cel/docs/Probe..._Tektronix.pdf
    Jo
    8,496
    I found these being thrown out.
    The dude reckoned they worked.
    No leads or anything, but in very clean condition and tagged (ohs) up until 2005.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,465
    I have a similar one to the one on the left, its a Trio 20MHz osilloscope. Was around $800 new when I purchased it 30 years ago.
    Jo leads should be easy to obtain from Ebay, Element 14 or local electronic stores.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Oct 2012
    601
    I've got two, only need one. The one I am willing to part with is a Phillips 2 channel CRT analogue scope, no storage or anything fancy. I think it's a 100MHz bandwidth scope. I can supply it with the service manual but no probes. If you want it let me know, you can have it for a 6 pack of something decent.
