DFZ camshaft specs
Results 1 to 7 of 7
    Fellow Frogger! chez00's Avatar
    567
    Default DFZ camshaft specs
    Hi all,
    Does anyone happen to have the stock camshaft specifications for the 205 dfz? Specifically the lift@TDC so I can dial it in. Cheers
    1988 205 GTi XU10J4
    2001 406 Monaco 5sp V6
    7,568
    Not sure of the lift @ TDC, but here's the rest.
    LCA 112
    Max Lift 0.405"
    Adv. Duration 276 deg
    Duration @ 0.050" 218 deg.
    Post it up once you've dialed it in @ 112.
    567
    Will do thanks Peter
    1988 205 GTi XU10J4
    567
    I have an installed centerline @ 113 (near enough!). Measured on the bucket with .007" clearance, lift @TDC is .028". Hope this helps the next chump, certainly the long way round with a dial wheel!
    1988 205 GTi XU10J4
    7,568
    I was thinking it had to be around 0.040-0.050", less valve clearance. So you're on the money. I'd advance it 2 deg and see if it improves.
    567
    Do you mean advance it 2 more degrees or 2 degrees from 112? Will this change my spark advance requirements in your experience?
    1988 205 GTi XU10J4
    7,568
    Move it to 110 deg.
