MI16 BE1 with LSD Gearbox oil options
Results 1 to 16 of 16
    Fellow Frogger! clayts's Avatar
    Perth
    161
    Default MI16 BE1 with LSD Gearbox oil options
    Hi Froggers,
    My plans for this weekend are to re-fit the flywheel, new clutch and gearbox back on the 205.
    The gearbox is the BE1 from the MI16 plus its worth mentioning I have an AP Suretrac LSD fitted.
    What is the best option for gearbox oil that is available locally?
    clayts
    Current: 1989 Peugeot 205 GTi [Mi 16]
    Previous: 1989 Peugeot 205 GTi [stock]
    7,569
    Castrol Syntrax is probably your best choice, from Repco, Supercheap etc. If you had more time, you could buy some Redline Light Shockproof from here:
    http://www.ebay.com.au/itm/Redline-L...item27b6077642
    Fellow Frogger! Karoshi's Avatar
    Feb 2011
    270
    Ooooo, Eastwood is near me and I havent bought gearbox oil yet. Price is very similar to syntrax, how much better is it?
    Road car ok?
    7,569
    Google smurf blood. It's great for gear ATB type diffs but not for plate type diffs. Local RRP is probably 2x Syntrax. Buy your Mobil1 from Eastwood too.
    435
    I use either motul FF LSD oil or Nulon LSD oil, both have worked well for me (Nulon is alot cheaper)
    Current Stable
    Nissan Patrol
    2018 Mercedes Vito
    Renault Megane 225 Cup
    Ford Sierra XR4ti
    Ford Sierra Cosworth (Track Car)
    1971 Mini Clubman
    Previous Pugs
    1997 306 formula 2 kit car (Gravel Rally Car)
    87,88,89 and 1990 205 GTI
    2007 407 HDI
    1989 405 Mi 16
    1998 306 XSI
    1991 405 Mi16
    1996 306 S16
    NSW
    639
    The only thing to consider is if you use the redline and then change for some reason, it does not mix with other gearbox oils. So basically it is a gearbox rebuild / clean out if you no longer wish to use it.
    I personally use the syntrax .
    I pulled my gearbox apart after 8 plus years of competition use and it was as clean inside as when I built it with no wear.
    Others I have pulled apart with different oil were filthy and worn
    Adrian Wuillemin
    Feb 2011
    270
    I don't fancy not being able to change my mind if there's a problem so that's made the decision for me!
    cheers
    Bill
    Perth
    161
    Thanks for all the help.
    When the gearbox oil was drained a few weeks ago, I was surprised at how fresh it looked. And it had been at least 4 years since the last change.
    Given the info in this thread, I will probably go with Castrol Syntrax.
    2 litres to fill, right?
    Via the aussiefrogs App
    NSW
    639
    yep, 2 litres
    Adrian Wuillemin
    7,569
    You may struggle to get 2L in unless you jack up the LH side of the car.
    Sent from my Commodore 64.
    NSW
    639
    Fill it from the breather on top of the box. Take out the black plastic breather and pour it in.
    Adrian Wuillemin
    Perth
    161
    Thanks. Looking forward to the weekend to get the 205 back on its boots.
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,016
    how would you go about flushing out old gear oil? mine got contaminated with other gear oil, also blue in colour, hence the stuffup
    Feb 2011
    270
    Syntrax seems to be selling like hotcakes. I've been to two auto stores near me and both sold out.
    Adrian, if I change my mind and want to go to redline, is there a problem? Will whatever you lubricated my box with to put it together be compatible with the fancy stuff?
    i will be calling around tomorrow but just in case...
    7,569
    You could also use the Mobil1 equivalent of Syntrax for approx $14/L.
    http://www.gllubricants.com/index.ph...obil-Pricelist
    Perth
    161
    http://productsforyou.castrol.com.au...Plus-75W-90/66
    I see that Castrol have replaced the Syntrax with a 'new' version. Is this product still suitable with the suretrac LSD?
