205 GTI loss of power then cuts out.
Results 1 to 9 of 9
    Fellow Frogger! Aprilia's Avatar
    Apr 2012
    Rosebud Vic.
    175
    Default 205 GTI loss of power then cuts out.
    Hello All
    my 87 GTI with the S3 engine & Motronic transplant has been running for 1500 kms, starts easily and idles smoothly, it has some serious sputtering at low revs under load and will sometimes will cut out but restart easily.
    Today a big power loss in low revs and no restarting for about 30 minutes, did this 3 times and I walked home 3kms, went back later started up, died after 2kms, started again and limped home slowly.
    1 hour later it has spark and fuel to rail. I should have checked this when the engine died.
    It has a full tank of petrol, Any ideas would be appreciated.
    Thanks Doug
    mullumbimby
    879
    Check any sensors with air vaccuum rubber tubes...... for perishing..... allowing ingress of air. Screws the mixture. In my case on a 306 problem was map sensor and caused the thing to run way too rich.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,468
    Been wet in Melbourne? Check that O2 sensor cable connector is dry (and clean). Just a thought.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    1000+ Posts gezza's Avatar
    Bunbury
    2,195
    Coilpack.....
    Armidale
    2,690
    Fuel starvation? Assuming you have an in-tank pump, check the strainer on the bottom of the pump (as well as replacing the fuel filter ).
    Alec
    1000+ Posts djvu205's Avatar
    1,415
    Ignition module is worth a look
    Apr 2012
    Rosebud Vic.
    175
    Tommorrows purchases : from EAI, coil & fuel filter. I have a spare oxygen sensor and I imagine its a pull out the rear seat to acces the fuel pump strainer, also where is the Ignition module?
    Thanks Doug
    1,415
    if its an early car with motronic management could be in a different place be should be on the drivers side near strut tower/fuel filter. most likely a bosch unit with seven pins?
    Apr 2012
    Rosebud Vic.
    175
    Installed the coil and the fuel filter, no more sputtering and runs like a dream, a pleasure to drive.
    Thanks guys
    Doug
