Paper water pump gaskets - sealant?
Results 1 to 25 of 27
    Gone Fishin' Haakon's Avatar
    May 2002
    canberra...
    8,898
    Default Paper water pump gaskets - sealant?
    What's the local wisdom - yay or nay for sealant?
    Have used the black Permatex (little bottle with a brush in the lid) previously without issue, but I'm out of it and was considering a smear of some high temp silicon I have.
    Then I noted a lot of folks saying to use them dry... Confused.
    Am inclined to go and buy some more Permatex...
    19,469
    I'd use permatex rather than a silicon base sealant.
    Perth Western Australia
    2,712
    Ditto, Permatex Non Hardening type. Ideal for alloy hose spouts to prevent corrosion.
    19,469
    ...Ideal for alloy hose spouts to prevent corrosion.
    I've used telflon tape wound around the spigot instead of permatex, seems to work as well without the gooey mess.
    The yellow gas tape, which is a bit thicker is best.
    The same technique is also a good bodge for making male threaded fittings seal when pushed into and clamped to a hose. My water recycle system is full of such joints.
    7,567
    ThreeBond 1211.
    1000+ Posts Beano's Avatar
    3,247
    Use water pump paper gaskets dry ? Never ! There are too many little irregularities which need filling in. Even a tiny bump or scrape across the mating surfaces WILL cause a leak after it's put on......sometimes even only at atmospheric pressure. Happens no matter how clean you think you've got the surface.
    It will cause you to think that the pump seal is defective.
    I had it happen 3 times before I swore to never do it again.
    For many years now I've been using high-temp silicone.....no probs.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,470
    I use paper gaskets smeared with grease so that they come apart easily, never had any leakage problems.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    May 2002
    canberra...
    8,898
    Supplied gasket is quite thick paper, almost squishy. So can imagine it might be ok dry.
    OE gasket was a rubber coated metal gasket - that goes in dry.
    Shall aquire some Permatex, it's good stuff. Has a glue like function silicon doesnt, just a very light smear.
    7,567
    It's only ok compared to ThreeBond 1211. It's not until you pull it apart that you'll appreciate its quality. Smear a light coating each side of the gasket.
    May 2002
    canberra...
    8,898
    Threebond is a silicon sealant? Best one of those I've used is the orange stuff (dont make me go out to the shed to get its brand.. Think it might be a permatex).
    Got a good grey coloured Loctite brand silicone for the Xsara (EW10) sump which is a gasket free caper - that seemed pretty good for that application (hasn't leaked at any rate!).
    Am thinking though that silicon sealants on paper gaskets is not ideal - not convinced as yet it bonds all that well to paper.
    Dec 2002
    CANBERRA
    401
    Me too.
    It's how I roll...Brisbane
    34,220
    Ive tried and failed with silicone based sealants on water pumps and have gone back to old faithful 'gasket goo' smeared on both sides of the paper gasket. Just give it a good 24 hrs to dry before adding the coolant.
    Footnote: whatever sealant you use just make sure you don't get much down any blind holes or the bolts might not go all the way in (don't ask me how I know).
    Every day when I wake up I reach up in the darkness with my eyes shut and if I cannot feel anything that resembles a wooden lid I know it will be a good day. No lid today.
    7,567
    I fit Mi16 thermostat housings direct to the head with just 1211.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,470
    Its good to see all the different methods and products that people use, and also what works and what doesn't.
    Regards Col
    1973 Alpine A110
    Oct 2002
    Melbourne Victoria
    13,065
    Always used the permatex style gasket goo, but with a thick paper, the grease will also work too, and come apart as Col says, if I used grease, I'd do a light smear of silicone on the aluminium pump side or the engine side, silcone uslually stops alloy corrosion, so I use a smear around the outlet pipe where it contacts the hose. I find silicone great to use when alloy pipes are pitted with corrosion, wire brush them first to get rid of the active corrosion, then the silicone fills the hollows and prevents further corrosion. Use a good quality silicone sealer.
    Silicone without a paper gasket is an excellent sealer, but might be hard to remove the pump later!! As long as you have clearance on the impeller blades, silicone on its own is o.k. I wouldn't stress too much if I was out of gasket goo, though the last tin continues in use for the last 15 to 20 years....
    Ken
    8,496
    Unlike most people who replace the water pumps, I seem to be changing engines and keeping the waterpump, so I grabbed the hylomar spray last time and nothing bad has happened.
    Jo
    7,567
    There's silicon and there's silicon. The beauty of 1211 is how easy it releases from the surface at clean up time. You just rub it with your fingers and it peels off. Yet when under compression, it seals like nothing else. It was designed for sealing motorcycle gearbox cases, metal-metal under high vibration situations. Anyway, I'm not going to talk it up anymore. Try it and see.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,470
    What brand is it Peter?
    Regards Col
    1973 Alpine A110
    1000+ Posts dino's Avatar
    Nov 2002
    5,049
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,470
    Quote Originally Posted by dino View Post
    Thanks Dino, I have a leak in the Alpine transaxle that will need fixing soon, so will try it on that.
    Regards Col
    1973 Alpine A110
    5,687
    All ThreeBond stuff is top shelf and price. Great for metal to metal.
    "The enemy of knowledge is not ignorance, it's the illusion of knowledge"
    Stephen Hawking
    9,415
    Yep. Threebond used here too. Recommended by a friend who runs metho dragsters and it's the only thing they use everywhere on the engine.
    For a run of the mill scenario though, oiling/greasing the gasket should be more than enough. Jo's Hylomar works too, no probs.
    There is also the silicone based grease (not to be confused with silicone sealants), really tacky stuff, never goes hard, resistant to high temp and pressures. Used in the food industry on their machinnery (food grade). Made by Dow Corning. Careful though, it doesn't wash off your hands with anything so you're just going to have sticky fingers for a while, hehehehe! (not soluble in water, oil or any petrol products, which is why it's so good around the engine).
    ACHTUNG ALLES LOOKENPEEPERS
    Jul 2004
    803
    While some sealants seal better than others, the key is in the prep. Mating surfaces have to be spotless and free from any trace of oils. Paper gaskets and greasing them is very last century imo, but if it works for you do it. That said I have fitted many renault pumps with just the paper gasket and nothing else without incident. Permatex products (ultra grey, blue, black, with the exception of the aviation form-a-gasket which is required in certain applications) are useless and even worse to remove. Hondabond, Yamabond, Threebond etc pretty good. Wurth silikon spezial- ok at sealing but looks god awful in its fluro green and orange and a major pain to remove. But the best I have found so far is Loctite Instant gasket. It comes in a neat pressurised cylinder with a trigger. It's oe specified, Sets firm- but if you have the right tools cleanup is not a problem. I havent had anything that ive sealed with it come back leaking. But FWIW I have seen cylinder head camboxes sealed externally with selleys all clear bathroom silicone with no leaks- so what ever works really!
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
    Jul 2004
    803
    Quote Originally Posted by Kenfuego View Post
    Probably one of the best reasons to use a silicone sealant for cooling system components.
    2006 Peugeot 206 Xt
    8,496
    Quote Originally Posted by James504 View Post
    ...But the best I have found so far is Loctite Instant gasket. It comes in a neat pressurised cylinder with a trigger. It's oe specified, Sets firm- but if you have the right tools cleanup is not a problem. I havent had anything that ive sealed with it come back leaking.
    Good to hear a reveiw of that stuff.
    I bought some (and its not cheap) and on the first squeeze of the trigger, the nozzle and shaft fell clean off, with no chance of ever working again. I got my money back and jut bought the usual permatex ultra black.
    So my first and only impressions of it was that it sucked.
    Might give it another go if the need arises.
    Whats its shelf life like, can you use it 6 month later or does the nozzle block??
    Jo
