can i ignore a tapping top end or that asking for trouble?
Results 1 to 11 of 11
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,016
    Default can i ignore a tapping top end or that asking for trouble?
    gti6 motor i had for my 205 was sitting for about 3 months before it went in and now its running. Ive done a timing belt on it also but the exhaust cam slipped my grasp and now im worried that ive bent a valve(s). very light tap, wouldnt be heard in the cabin i dont think, becomes louder at higher RPM. also worth noting that the oil is penrite 10w-50. cant drive it yet but only let it sit idling at most 5 minutes.
    If its not a sticky lifter (which i hope should clear up if driven hot) and the oil isnt too thin for the motor (less than 100,000km i think about 70k), is it ok to leave it as it is? if its bent it would be only slightly bent from clashing with each other when i timed it up (got a solid lower pulley too). Im an apprentice and cant afford 16 valves & guides, cylinder head service and a head gasket at the moment, was hoping maybe leave it 6 months or so if im to pull it apart then to upgrade the motor..
    7,567
    Hornsby, NSW
    1,016
    Excellent. I shall purchase one for myself. Just concerned though if i'll cause more serious damage driving it in to work and use theirs instead. If its just a noise then im really not bothered.
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,468
    The 6 motor I started after sitting for 12 months ( fresh fluids, plugs out etc ) took about 15 minutes for the tapping to go away. Even a compression check should show up differences?
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Hornsby, NSW
    1,016
    i dont remember if i spun it clockwise back round again! what a bellend I am lol it would probably wreck all of them if i did..sh7t.
    Hornsby, NSW
    1,016
    and ive answered my own question.
    http://forum.205gtidrivers.com/index...4227&hl=valves
    Jul 2004
    803
    I guess you have to look at the positives here. 1- it wasn't a customers car. 2- you'll never make that mistake again(we hope.) The gti6 stikes again.
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
    Hornsby, NSW
    1,016
    Quote Originally Posted by James504 View Post
    1) true that
    2) time will tell
    3) to be fair its an Xsara VTS motor
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    21,245
    oops, tough way to learn, but I guess most of us have been down that road at least some of the way. Good luck.
    Hornsby, NSW
    1,016
    i'll take it as a yes that i should replace valves and guides? at least the only cost to me is the guides, valves, head gasket and head bolts, and a head service obviously. might be staying standard for a while!
    Hornsby, NSW
    1,016
    compression tested (dry, cold) 220 PSI across all 4, all on 6 compression strokes..190 after 4 which is ok. onto a leak down test, if its ok i'll leave the head alone and drive it, see how it goes.
