Which BE1 Gearbox do I have?
Results 1 to 15 of 15
    Fellow Frogger! clayts's Avatar
    Perth
    161
    Default Which BE1 Gearbox do I have?
    Hello All,
    I have a 205 with the 16V conversion. I need to replace the clutch, but as I did not do the conversion during my ownership, I am unsure of the gearbox.
    I know that it is the BE1 box, but is it from a 205 or 405?
    If it is the BE1 from a 205, then it will require the 205 BE1 release bearing;
    Otherwise it is from a 405 Mi16 and will use the 205 BE3 release bearing.
    Am I right in that the pressure plate and friction plate for the clutch will be the same (1.9 405 Mi16), just the release bearing differs?
    Before pulling the gearbox off the car, is there a visual difference?
    I have tried to take photo from above, showing the clutch arm. But the battery tray does obscure the shot.
    Thanks in advance
    Justin
    Current: 1989 Peugeot 205 GTi [Mi 16]
    Previous: 1989 Peugeot 205 GTi [stock]
    7,568
    I'm confused. That looks like a BE3 arm.
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    21,254
    Mine is a 205Gti Be1 box. Photo below for reference
    Perth
    161
    BE1 is identified with Reverse being next to 1st, right?
    Jul 2004
    803
    Thats a Be1 from a 405. ^yep.
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
    Perth
    161
    Quote Originally Posted by James504 View Post
    So it makes sense that the gearbox came with the 16v.
    So I will need the standard 215mm 405 1.9 Mi16 clutch, but a BE3 release bearing. Didn't all clutches in the 405 Mi16 use the BE3 style bearing, regardless of BE1 or BE3 gearbox?
    Jul 2004
    803
    Correct. A clutch kit for a 1.9 Mi16/bx16v will come with the correct throw out bearing.
    2006 Peugeot 206 Xt
    1,389
    I though the clutch kit would be governed by the flywheel? I have a 405 flywheel with a 205 (Be3) gearbox thus I have to buy a 405 clutch....
    Perth
    161
    Quote Originally Posted by PugMonkey View Post
    Ok, is this because the 405 flywheel is 215mm, where as the 205 flywheel is 200mm - so your clutch plates will need to be from a 405? But the bearing is gearbox specific?
    In my situation with my XU9 16V (Mi1
    6) engine, assuming the flywheel will be 215mm, all I require is a clutch for the 405 Mi16 1.9L.
    1,389
    Default Re: Which BE1 Gearbox do I have?
    ...yes!
    Sent from my GT-I9100 using Tapatalk 2
    Perth
    161
    Thanks all for the assistance
    Perth
    161
    Anyway, bit of an update today.
    Good thing I didn't order a new clutch before removing the old one because the flywheel is from the 205, being 200mm in size.
    So even though the gearbox is the 405 BE1, and the engine Mi16, the flywheel is from a 205. The clutch removed today was very worn which explained the slipping. The clutch was a paddle style, so perhaps a previous owner purchased the upgraded clutch, found it would not fit the Mi16 215mm flywheel, and used an 8v flywheel instead.
    NSW
    639
    The 205 clutches are rubbish. Get an mi16 flywheel and clutch. All the bell housings are he same size where the clutch lives.
    Adrian Wuillemin
    Jan 2011
    Traralgon
    649
    And while you are at it, check the plastic bushes for wear. I didn't recognise this problem in my 405 and broke 2 x clutch thrust bearings before I realised what the problem really was. I also have a spring over the lower portion of the clutch fork vertical shaft to prevent it applying any vertical load to the bearing retainer. Mine does get a pretty torrid time though - track work exclusively and I pop it between gears pretty agressively.
    racing 405
    1:59:09 last time at Phillip Island - less than standard Mi16.
    Perth
    161
    The clutch pulled out was a performance clutch from Walkers Garage in the UK, and will be rebuilt locally by a friend with a high quality compound.
    Otherwise I would source a 405 flywheel/clutch combination.
