Peugeot Mi16 misfire
Results 1 to 3 of 3
    Fellow Frogger! Ceenine's Avatar
    Devonport, Holiday Coast
    513
    Default Peugeot Mi16 misfire
    I am in the process of finalising putting motor back together. I am getting a misfire on nos. 1 and 3 coils. I have swapped over coils and determined that it is not the coils at fault. I have checked the connector at the flywheel end to a certain extent but probably need to check it out more exhaustively. Any clues what else I can do without locating a computer to plug in. Computers are not exactly thick on the ground around these parts.
    Thanks in anticipation
    2014 C5 2.2 HDI Limited Edition Sedan
    2007 C5 2.2 HDI Hatchback
    2007 C4 1.6 HDI EGS Sedan
    Peugeot Mi16 Series 2
    Boolarra vic
    44
    here is the image I tried to send you yesterday:
    Trevor
    Boolarra vic
    44
    Default Ignition Modules?
    Don, I suggest you check the ignition modules mounted on a heat sink between the battery and the wheel arch. Each supplies 2 cylinders. I once forgot to re-connect one and had an engine running on two cylinders...
    Trevor
