205 BE3 gear linkages
Results 1 to 16 of 16
    1000+ Posts djvu205's Avatar
    1,415
    Default 205 BE3 gear linkages
    the linkages on my car seem to be slopy to say the least the gear lever bush is ok just seems the rods and maybe the bush on the subframe are knackered. can anyone recommend a one stop shop where i can buy uprated bushes and rods? not sure if i need them but ive heard that rose joint are a good way to go?
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,016
    mine were at a stage where they were popping off by themselves, especially one near the exhaust, had to put that on a few times :/ replaced with genuine no slop and nice and tight.
    1,415
    i Know Baker bm and pugracing do uprated ones, i have considered std items but the quality doest seem top be there anymore. its dissapointing to buy geniune parts that are worse than aftermarket bits.
    for example not long ago i bought a new geniune clutch cable, after fitting gearbox and testing it snapped first press. ended up putting old cable back for time being. the pissy little piece that is crimped onto the wire cable simpley pulled through and it all fell to piceces.
    i found these http://www.constella.co.uk/index.php...k=1&Itemid=167
    1000+ Posts pgti6's Avatar
    May 2001
    1,670
    I've got some of Miles (Pug Racing) gear rods on the 405 & they have a circlip which prevents them from popping off. Well worth the price IMO.
    http://www.pugracing.com/index.php?d...ducts-gearrods
    405 Mi16 2.2 litre race car for sale.
    http://www.aussiefrogs.com/forum/car...-car-sale.html
    https://www.my105.com/ListingDetails...d/518/id/22164
    Lap times- Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205 Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Mar 2005
    Here
    203
    Quote Originally Posted by pgti6 View Post
    Ditto
    Miles supplies reliable gear from my dealings with him.
    These ball end with clip rods improved the shift 'feel' ( but I guess that could be my imagination )
    If you are going to use stock then the ball joint near the exhaust needs the little heat shield put back on.
    Peugeot put it there for a reason - stops the nylon cooking a perishing prematurely.
    93' 205GTi
    'don't force it son - use a bigger hammer'
    1,415
    ended up getting some a set of 3 rods from miles, also grabbed a new ball and nut for subframe and some bushes for the L bracket and shifter. all up cost about $100
    NSW
    639
    You need to do some work to the L bracket.
    They are pressed together and work loose
    Just need to weld the two.
    Whilst you are there, cut 1 " out of the short arm.
    Adrian Wuillemin
    1,415
    thanks for the tip Adrian, i have considered the shortened L Bracket but ive heard once the linkages are refurbed its not to bad so will see how it goes
    NSW
    639
    heaps nicer with the shortened L bracket. Keeps the same side to side movement and just reduces the front to rear movement of the gear lever.
    Adrian Wuillemin
    Fellow Frogger! patpug's Avatar
    614
    Default RE: 205 BE3 gear linkages
    Quote Originally Posted by Adrian Wuillemi View Post
    +1 for this mod from me. Makes a big improvement in the driving experience. I replaced all the rods with pug genuine items at the same time and no probs so far 3yrs later.
    205 gti-6
    205 track car build in progress http://www.aussiefrogs.com/forum/res...-race-car.html
    1,415
    dont spose anyone would have a spare modified one they want to sell me? id like to keep my std one if possible incase i decide to put it back.
    NSW
    639
    Yeah.
    Will package upo with regulator f you like
    Adrian Wuillemin
    1,415
    ok sounds good Adrian
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,467
    Adrian Im heading down to pick up the motor form Lauree next week, I can take it down with me if its ready on Sunday?
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Fellow Frogger! chez00's Avatar
    567
    Thanks for the tip on the L bracket, that sounds the goods!
    NSW
    639
    No Problem. It will be ready.
    Adrian Wuillemin
