which engine mi16 s1 s2??
    1000+ Posts gezza's Avatar
    Bunbury
    2,195
    Default which engine mi16 s1 s2??
    Just curious as I am toying with this idea, I am curious to know which engine is easiest/best to fit into my 1994 series 3 205 gti??
    There is a few engines for sale and I like the diea of 16v power in a 205!!!
    Can anyone help/advise which is my best route??/...
    Bunbury
    2,195
    No one want me to butcher a std S3??...!!!
    7,569
    I would. Keep the standard engine/gearbox/ECU at the back of the shed. In order of fitting difficulty, not including wiring/ECU:
    XU10J4R - exhaust bolts straight up, but ideally needs a lower top mount.
    XU10J4 - exhaust flange is larger diameter & PCD, so needs 16V downpipe, ideally needs a lower top mount.
    XU10J4RS - exhaust needs a wedge plate, ideally needs a lower top mount.
    XU9J4 - needs shortened inlet manifold and exhaust wedge plate
    Ask me off-line about lowered top mounts.
    Wiring/ECU
    XU10J4R - only has 60-2 crank angle sensor, so can only be multipoint fuel and wasted spark
    XU10J4 - has 60-2 + camshaft home trigger, so can be sequential fuel and wasted spark or direct fire
    XU10J4RS - has 60-2 + camshaft home trigger, so can be sequential fuel and wasted spark or direct fire
    XU9J4 - only has 60-2 crank angle sensor, so can only be multipoint fuel and distributor or wasted spark
    Mods
    XU10J4R - can take up to 0.380" cam lift, limited by single valve spring
    XU10J4 - can take up to 0.430" cam lift and can take approx 0.100" lift @ TDC
    XU10J4RS - not sure of maximum cam lift, but shallow pockets limits cams to approx. 0.055" lift @ TDC
    XU9J4 - can take up to 0.430" cam lift and can take approx 0.100" lift @ TDC
    My favourite? The XU10J4 with either XU9J4 or XU10J4RS inlet manifold.
    Bunbury
    2,195
    Cheers for that Peter pm sent
