Peugeot 406 brake disc minimum thickness ?
Results 1 to 3 of 3
    1000+ Posts Beano's Avatar
    3,247
    Default Peugeot 406 brake disc minimum thickness ?
    After having a quick look on the net for disc thickness, I've found a few figures from the UK.
    Does anyone know what the Oz figures are ? (If they are different)
    Would it be true to say that the rule of thumb would be that only 2 mm of wear is acceptable ? This is the impression I get from the UK figures.....
    271
    Front discs
    Diameter: 260 mm
    Thickness: 24 mm
    Minimum: 22 mm
    Diameter: 283 mm
    Thickness: 26 mm
    Minimum: 24 mm
    Diameter: 305 mm
    Thickness: 28 mm
    Minimum: 26 mm
    Rear discs
    Diameter: 290 mm
    Thickness: 10 mm
    Minimum: 8 mm
    The 1.8 petrol and 1.9 diesel (without intercooler) were fitted with 260 mm discs, which weren't available here.
    Australian delivered 406 models should be fitted with 283 mm discs, unless you have the V6 coupé (305 mm).
    The minimum thickness might also be engraved on the edge of the disc itself.
    Jun 2011
    Tasmania, Australia
    226
    Thickness sizes will be cast into the rotor inner housing (minimum)
    Alain
