403 electrical issue.
Results 1 to 3 of 3
    Fellow Frogger! sideways_505's Avatar
    Perth W.A
    390
    Default 403 electrical issue.
    Hey guys. The 403 has developed a big electrical short somewhere, at first it would still run and everything worked as normal, the battery just went flat super quick.
    The next time I tried it nothing worked at all, you just get big sparks when you connect the battery.
    I have no idea where to even start, any ideas AF?
    Hayden
    1985 S2 505 GTi. Someone please sell me an S2 drivers side front 1/4 panel so I can get this on the road again.
    1985 S1 505 SRi. Parts car.
    1957 403 sedan. Aka Ruby.
    1979&81 Suzuki LJ81s.
    1980 Suzuki LJ80V.
    1981 Suzuki SJ40 Sierra.
    2000 Suzuki Jimny.
    19,485
    First disconnect any wires off the battery/ main solenoid terminal which look non standard
    Next is to disconnect the voltage regulator heavy wire which heads to the ammeter.
    After that disconnect the smaller ring terminal on the starter motor main feed terminal.
    One of these should stop the short.
    PS You have checked the main battery feed to the starter solenoid is not shorted to ground somewhere? Often a lug touching ground.
    Perth W.A
    390
    You might not believe this but there are no non standard wires from the terminals!!
    I'l try those things, hopefully today and get back to you.
    Hayden
    1980 Suzuki LJ80V.
    2000 Suzuki Jimny.
