Where's the Tachometer wire - s1 205?
Results 1 to 7 of 7
    Fellow Frogger! chez00's Avatar
    567
    Default Where's the Tachometer wire - s1 205?
    Hello,
    Anyone know which one is the rev counter wire (signal)? 12/88 205 Gti. Thanks!
    7,567
    The fat light green shielded wire.
    567
    Hmm, that wire terminated at a seven pin relay. I removed the lot when I was installing my new loom and now I cant figure out what wire it connected to. Any hints upstream?
    7,567
    The same wire (electrically) joins the following four items:
    - ignition coil (-ve)
    - tachymetric relay
    - tacho
    - ecu
    567
    Thanks, worked it out from there. For the record, the signal wire is light blue. Tachometer works great with the resistor swap and aux out from my vipec. She's going on the roller dyno tomorrow for a full map, should be interesting.
    1988 205 GTi XU10J4
    2001 406 Monaco 5sp V6
    9,548
    Anyone have any idea what a 205 SI tacho is looking for in the way of input?
    I would like to get it working in the rally car which at present is running stone age dissy and coil.
    Graham
    Quote Originally Posted by chez00 View Post
    7,567
    Given the Si is wasted spark, the tacho must be getting a feed direct from the ECU. In which case it's more than likely 12V square wave.
