Synchronising Quad Throttle Bodies
Results 1 to 8 of 8
    1000+ Posts pgti6's Avatar
    May 2001
    1,671
    Default Synchronising Quad Throttle Bodies
    I had to dismantle my throttle bodies to do some work on the manifold and now that I'm re-assembling it I want to get the 2 bodies as close to being synchronised as possible.
    Last time they were done properly with a vacuum gauge fitted over each ram tube/trumpet with the engine idling & adjusted for evenness across each pair of bodies. The engine isn't ready to run so that method can't be used yet.
    With a lead light shone up through each branch of the manifold, you can see a small difference in light visible with the butterflies in the closed (idle) position. Difficult to see on the pic and it's only slight, but there is a difference.
    Question is, even though I'll use the vacuum gauge method again prior to the full engine tune should I bother with the light method to get them closer adjusted, or just leave it as is for the cams run-in period?
    405 Mi16 2.2 litre race car for sale.
    http://www.aussiefrogs.com/forum/car...-car-sale.html
    https://www.my105.com/ListingDetails...d/518/id/22164
    Lap times- Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205 Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    NSW
    639
    Buy four drill blanks, say 3mm diameter and put under each butterfly. This will let you adjust the linkages to ensure they sit flat on a none known surface.
    Adrian Wuillemin
    May 2001
    1,671
    Good tip! Thanks Adrian. Job done
    Previous Frenchies-
    1988 205 Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1000+ Posts Dave's Avatar
    Apr 2001
    1,339
    On the motorbike I use a bit of fishing line or similar like a feeler gauge.
    Dave
    Fellow Frogger! Roland's Avatar
    Perth
    728
    Rig up a vacuum cleaner to suck air through the body. The you can use the vacuum gauge method with great accuracy.
    Ipswich, Queensland.
    1,976
    Quote Originally Posted by Dave View Post
    Dave
    Similar to this I use a piece of fine fuse wire. Then when the engine is running I listen to the suck through a 500mm piece of garden hose to make sure. I am sure the various vacuum type guages work fine. My method came about from my sidedraft Weber days. Cheap and effective, at least for me.
    '56 Renault 4CV (16TS Power)
    '62 Renault Dauphine Gordini
    '82 Renault Fuego GTX
    May 2001
    1,671
    All good suggestions. Thanks guys.
    The one my tuner used was something like a trumpeters mute which fitted into/over the ram tube. He said he'd had it since his early Holden tuning days circa 179, X2, 186/S, 202. Can't remember how the vacuum gauge was fitted 'tho. (i'm usually a bag of nerves on dyno day)! I Googled 'vacuum gauges' & variations but couldn't find anything like it.
    I used Adrain's method with good success & as Dave said you can 'feel' & adjust for evenness between butterfly & body.
    Previous Frenchies-
    1988 205 Gti
    1998 306 GTi6
    1997 306 N5 sedan
    bob
    bob is offline
    May 2001
    Skipton
    2,581
    G'day,
    way back when in olden times we also had vacuum gauges to check idle balance on carby setups, however, as it was done with the butterflys closed more or less other leakage factors came into the arguement to a great extent and made the system pointless.
    We found it better to ensure that the little fellas were fully open together and to hell with where they sat at idle. Best way is with a couple of ordinary drill shanks, same size of course, as mentioned above. Pick a drill size that opens the butterflys about a quarter to a third, hold the butterflys with the fingers and tighten the clamps - always assumes that each butterfly has been correctly seated in the shaft first !
    cheers,
    Bob
    BTW, reckon that there's one of those gadgets in the shed somewhere, if I can find it I'll post a picture or two.
