205 gti Oil cooler hoses??
Results 1 to 8 of 8
    Member OLi205GTi's Avatar
    Apr 2005
    Essendon, VIC, Australia
    46
    Default 205 gti Oil cooler hoses??
    Hi all, the 205 blew an oil hose on the freeway yesterday. although the ensuing cloud of smoke and I oil was rather spectacular(!), i would now like to source some new hoses to ensure it doesn't ever happen again. (its the two that run from the engine to the oil cooler) has anyone had any luck with getting these? If not, i'm guessing the path is to get them re-made. If anyone has gone through this process it would be great to hear. Its a '87 S1 if it makes any difference.
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,016
    Try mobs like ENZED and pirtek. or keep buying second hand ones wink wink
    1000+ Posts djvu205's Avatar
    1,415
    didnt think s1 had oil cooler? is it the hoses that go from top rad hose to the heat exchanger/oil cooler? like s3 ones? im pretty sure i have really good secondhand ones.
    edit: i know the ones you mean now! brain was a little slow this morning i have some of those as well but would need to check condition if you end up sourcing secondhand items.
    7,567
    I've done a few. Cut off the original fittings and silver solder #10 fittings on the tubes. Use push on fittings & hose from Motorsport Connections. The hose is only sold by the metre. You need two 250mm hoses, so 1m will do two cars.
    Apr 2005
    46
    Thanks all, might try ringing those guys today. I havent quite got the expertise to silver solder up a set but good to know its possible. Djvu, If i have no luck ill be in touch.
    Fellow Frogger! DjB8V's Avatar
    8V'ville
    921
    Is silver soldering diffucult ???
    205GTI - 8 valve, single cam coolness.
    7,567
    You also need to drill/bore out the back of the #10 steel fitting to match the OD of the steel 205 tubes. If you can find some one else who needs a set I'll make you some. I could do them on an exchange basis. Fitting the push-on #10 fittings to the hose is the easy part. It's a far cheaper solution than new original hoses.
    Apr 2005
    46
    Thanks Peter, will definately keep that in mind. ill see how I go over the next day or so. Be in touch.
