Oil in 504 air filter
Results 1 to 24 of 24
    3,612
    Default Oil in 504 air filter
    I noticed oil dripping from the flue of the air filter and I had a look and there is almost a centimetre of oil at the bottom of the filter unit. The filter is made from what looks like shredded metal. The BX's I owned with the foam filters had to be kept oily, but this one seems to be a bit over the top?
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,479
    Hi Bertie
    Is it engine oil in the filter? If it is, it could be caused by excessive blow by.
    Whats the oil level like in the sump? has it lowered since you checked it last time?
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,274
    Or it could just be that the Pug has a really true oil bath air filter. As fitted by the factory. If maintained correctley the engine receives near 100% clean grot free air.....Check the owners manual!
    19,518
    Quote Originally Posted by Bad Bertie View Post
    This is correct. The air being drawn over the oil is a pre-filter system. The large lumps "stick" in the oil. The oiled gauze is the second part of the filtration. And a bloody good and simple system it is.
    You will notice the the bottom part of the filter has a plate . The oil level is correct when the plate "minimum" is just covered and the mark "maximum is not covered. Use standard engine oil.
    At every service the filter housing and gauze should be cleaned by immersing in a container of petrol and swilling around, then "blow" dried with compressed air. The gauze should be saturated, until it hold no more, with clean engine oil. The reservoir needs to refilled as mentioned above.
    You should check the large "o" ring between the housing and gauze unit to ensure sealing, as well as all the hoses/ rubber carby adaptor to insure the the induction system into the filter is completely sealed.
    Air leaks will let "dirty" air into the engine which has caused the demise of many XN series engines.
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,479
    Hi Bertie
    I forgot these cars have an oil bath air filter.
    If you don't have a manual you can down load one from here http://www.504.org/technic_GB.htm
    Regards Col
    1973 Alpine A110
    3,612
    Hi Bertie
    No, it does not seem to have lowered.
    3,612
    Hi Bertie
    Thank you very much Col.
    3,612
    Thank you rob for all the info. The engine is also a bit tappetty which I thought may have caused the excess oil? Otherwise the engine is nice and strong.
    19,518
    The filter has probably been overfilled. Or one of the filter to tappet cover brackets has broken off and torn a hole in the housing. This is very common on 404s which use the same style style of filter. This causes the oil in the filter to dribble over the tappet cover.
    XN engines can be are tappety for a few reasons. The valves are suffering recession due running on ULP fuel. The valve gear (cam followers as well) are worn due to high revving and infrequent oil changes. The tappets just need adjusting.
    Take off the tappet cover and look inside. If their a heavy crusty build up of crud and wax then it could be a lack of maintenance issue.
    Perth Western Australia
    2,712
    Rob,
    All your answers get the big tick from me. But..[I]"valve seat recession due to ULP fuels" ? [/I Valve seat recession causes tappet clearances to close up.
    19,518
    Rob,
    Valve seat recession of the worst kind can cause valve seats to become loose in the head. When tappets are adjusted, they can loose adjustment due to the seats moving.
    I've seen it happen in old clunker Holdens, in fact I had a valve seat fall out of the head and wedge a valve.
    I take your point that it's not the normal symptom of VSR.
    But , after all, nothing is straightforward of AF.
    3,612
    I have already soaked up some oil with a rag and will keep an eye on it. The previous owner did use a fuel additive for the ULP but I have not been using it as I have been told so many times it is not needed in the old Pugs and old Citroens for that matter as they have hardened seals. Is this correct?
    3,612
    I just found my 504 owners manual. I do have this Oil Bath Air Filter in my car fitted as an option in certain countries. Then it goes on by saying , every 5000 km, Remove the filter element and rinse using diesel oil ( diesel oil!) It should be re-fitted after drip drying. - Clean the bowl. - Pour engine oil into the bowl, up to the"LEVEL" mark, (260 cc app.). So there it is.
    9,569
    Definitely not, you need to use Valvemaster or Flash Tube, plenty of people have suffered valve seat recession in early Peugeots.
    First Peugeot to have hardened seats was 1982 505.
    Will be OK for short trips around town but any sustained cruising you will need to use additive or get hardened exhaust seats fitted,
    The inlet and exhaust valves and inlet seats are OK as is.
    Graham
    3,612
    Graham
    Ok, I shall use the additive then,thank you for that. And my 404 ute with a 505 engine should be ok without it?
    12,283
    or use a tin canister
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    9,569
    Yes.
    Also, use proper valve seat additive, upper cylinder lubricant won't do anything.
    651
    Quote Originally Posted by pugrambo View Post
    Groan.
    504 GL Coupe '73 Silver
    407 HDi Sedan '05
    Fellow Frogger! leftcoast's Avatar
    Feb 2011
    perth
    175
    with this oil in the air filter, what would be the worst thing about changing it out for a different aftermarket version with out the oil catch, i have a mod in progress but the air filter is in the way and need it to move right about 80mm, but there is no room, and the filter is to large, but dont want to get rid of the factory unit.
    would anybody recommend an aftermarket style pod air(only) filter for australian city suburb driving, its not like im in the desert and will prob never take it off road again,
    2,712
    Quote Originally Posted by leftcoast View Post
    Leftcoast,
    You could fit the alternative dry element "thermos" type filter from the later 504.
    Bad Bertie,
    Your engine breathing system may be clogged, check the gauzes in the oil filler spout also the vacuum fitting at the manifold.
    19,518
    I'll have a look for some images.
    It is possible to fit a dry filter inside the existing 404/504 oil bath case.
    It's necessary to drill a hole in the top and cut an aluminium disk for the bottom and use a piece of all thread to clamp the filter into the existing case.
    9,569
    Its the case not the type of filtering that is his problem.
    Feb 2011
    perth
    175
    Yeah changing it to just a pod filter would be ideal for room as id run a bent pipe with pod down behind the light, and keep all the factory vacume lines, guessing it shouldnt harm the engine ratios to much. I just have not seen it done before to an ti, and want to whey it up befor I start cutting and drilling
    Feb 2011
    perth
    175
    , what would be the worst case if blow by was to happen with a pod filter, I guess the original system was flawless in this aspect
