Replacement Motronic 60-2 Sensor
    7,569
    Default Replacement Motronic 60-2 Sensor
    I had few problems with a Motronic sensor on the dyno recently. Rather than replace with OEM, it was suggested to use a hall effect trigger as the output is less suspectible to noise. I drew and machined up an adapter to go in the standard hole. So now I have a 60-2 hall effect trigger.
    Attached Thumbnails Attached Thumbnails Replacement Motronic 60-2 Sensor-tdc2.jpg   Replacement Motronic 60-2 Sensor-tdc3.jpg
    1000+ Posts djvu205's Avatar
    1,415
    Peter what type of sensor is the original setup.is it vr? wouldnt mind doind something like that myself
    7,569
    What do you mean by VR? All I know is the standard one is reluctor and puts out a sine wave as opposed to a square wave on the hall effect. You'd need to verify with your tuner before going too far down that path.
    8,496
    Here is a good reference posted in another thread...
    http://www.picoauto.com/tutorials/trigger-signals.html
    Jo
    1,415
    sorry by vr i meant variable reluctance sensor. not acommodore
