Brake balance..?
Results 1 to 10 of 10
    Perth Western Australia
    2,712
    Default Brake balance..?
    One for "Rambo, or anyone with knowledge of 504/604 brakes?
    Is the 604 brake equalizer valve the same as later 504 ['79] ?
    Thread compatibility ?
    Ta.
    2,712
    Ta.
    As no replies to my post have been forthcoming I will soon be deleting.
    Come on out there someone must have the knowledge..?
    5,312
    Either no-one cares, or no-one knows.
    If it's any comfort, I don't know. And I don't care who knows it.
    Helpful?
    Mike.
    Started out with nothing, still got most of it left.
    5,312
    Still no takers?
    Surely somebody must know???
    Mike.
    2,712
    Mike,
    It seems they are being shy or coy..
    Thanks for your interest.
    I was handed a 2012 Franzose Catalogue to peruse. Quite a few different valves listed.. I have a new balance valve that I need to compare, it has a pressed metal lever that is connected by a "bed" spring to the suspension.
    The part number on the box...4861 19. It has ATE with the number 21 cast into the body.
    1000+ Posts djvu205's Avatar
    1,415
    ATE have a online catalog if thats any help?
    con
    con is offline
    sydney, nsw, australia
    526
    Ta.
    this is a very very interesting conundrum.
    According to factory catalogues, the 604 and the US 505 sedans used brake pressure regulator part number 4861.19.
    Yet EAI listing for late 504 and 505 sedans has a part number 4861.19: For the 504/505 wagons it is 4861.20
    con...
    2,712
    Quote Originally Posted by con View Post
    con...
    Thanks con. The numbers are looking good. The last number quoted for the wagons, because of their live axles?
    con
    con is offline
    526
    Presumably.
    Also, I misquoted the EAI number it should be 4861.18 - sorry: Shouldn't do these things at 1am in the morning.
    And did you know that you can get the internal rubbers to rebuild these limit valves from France -
    http://tinyurl.com/d9zfqq2. (GrahamW take note!).
    con....
    Dec 2004
    Devonport Tas.
    355
    Re the rubbers from France, they are fine but they don't include an "O" ring that is needed, also Con, you mention Factory catelogues, any chance of a copy or pointing towards accessing one for 505's?
    Neil
