DKZ engine installed, in need of Motronic conversion wiring info. 205GTi
    Fellow Frogger! Aprilia's Avatar
    Apr 2012
    Rosebud Vic.
    175
    Default DKZ engine installed, in need of Motronic conversion wiring info. 205GTi
    Hello all I installed the S3 DKZ engine & 4 speed Auto on Sunday into my S1 205 GTi. I left the manifolds off for better access for any loom modifications, so I can run the Motronic system.
    Any info on the wiring I need to add to my exsiting loom would be very helpful.
    I also have a Motronic loom from a 405, incase I have to modify and install or salvage sections from it.DKZ engine installed, in need of  Motronic conversion wiring info. 205GTi-img_0419.jpgDKZ engine installed, in need of  Motronic conversion wiring info. 205GTi-img_0425.jpgDKZ engine installed, in need of  Motronic conversion wiring info. 205GTi-img_0427.jpgDKZ engine installed, in need of  Motronic conversion wiring info. 205GTi-img_0431.jpgDKZ engine installed, in need of  Motronic conversion wiring info. 205GTi-img_0357.jpgDKZ engine installed, in need of  Motronic conversion wiring info. 205GTi-img_0334.jpg
    Before installing the engine I did the valve shims, timing belt, tensioner and pump. I also replaced the seals for the crankshaft, cam, diff, trans. While the engine bay was empty I dropped in a power steering set up from a 205 Si, because I had removed the gear shift mechanism and linkages the rack dropped in easily.
    Also have some shots at various stages.
    Thanks Doug
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,470
    Awesome effort. Never seen an auto in the GTi. Any reason behind this?
    I cant really help you with the wiring Im afraid. No real clued up on it. PeterT is the man you need to respond here.
    Good luck!
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    7,568
    Dob me in Cameron. If you send me an email, I'll send you an excel spreadsheet - sales@taylor-eng.com
    Apr 2012
    Rosebud Vic.
    175
    Hello Cam
    main reason for the auto trans is that I have an old hip injury and a couple of hours on a the heavy Gti clutch would be too much. But I luv everything else about the 205 GTi and when I bought the car it had a blown head gasket, then the S3 engine came along and I posed the auto trans question on this site and Adrian W (cant spell his last name) had done this convertion, so I went hunting for the bits.
    Also thanks for Dobbing in Peter T (easy name to spell)
    Apr 2012
    Rosebud Vic.
    175
    Peter thanks for those spread sheets, they will consume my evenings for a while.
    I posted some more wine cellar shots in (The Toad Pond) section under Blackwood Wine Cellar,
    I couldn't get them to your site.
    Thanks again Doug
