Trouble starting cold and lower idle that usual - 205 GTI
    Fellow Frogger! WhiteKnightGTI's Avatar
    Apr 2012
    148
    Icon4 Trouble starting cold and lower idle that usual - 205 GTI
    My pug has recently been having trouble starting cold. I'm having to put my foot down on the accelerator for a few seconds to keep it alive, and then it is fine.
    1. Is it bad to do this?
    2. What could be the problem?
    It also idles a bit lower than it used to. It sits around 800-900 and it used to be at about 1100. Could these 2 problems be related?
    Cheers heaps,
    Max
    brisbane
    2,927
    First thing i would check is your SAD....then clean the AFM....failing that could be your water temp sensor on the way out. Its blue and under the dizzy area. Good luck with it
    jr20516v
    Now:
    Exige SC [modded], 205 Si. 205 GTi , Megane R26 LY , Megane 225 [modded ]
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    Fellow Frogger! stew's Avatar
    Apr 2011
    brisbane
    507
    The usual cause is either a dirty throttle, clean with Carb Cleaner and /or the speed screw on the throttle body winding in or being in need of the gallery cleaned, a la throttle. The screw has an O ring to hold it in the thread, make sure it is good. Ensure the little hole in the fitting for the engine breather hose, the hose is about 10mm diameter pushed onto the TB. There is usually 2 of these, one for breather and one for carbon canister valve. When open one should pull a small vacuum( breather) one should be full manifold vac.
    Apr 2012
    148
    I fixed it with a slight adjustment of the idle screw. Thanks for the suggestions guys
