504 Ti missing on load when hot
Results 1 to 25 of 25
    Feb 2011
    106
    Default 504 Ti missing on load when hot
    Hi Froggers, it is at the mechanics now, but if you have a suggestions from experience
    it only happens on load when hot (full operating temp)
    ie after driving 15km or so
    otherwise engine is fine
    Nickc
    Blue Mountains, NSW
    454
    Ignition would be my first port of call. Points, condenser, leads, dizzy cap, coil would be the order I'd check.
    Have fun,
    Rob.
    Feb 2011
    106
    Thx Rob. Forgot to mention that the car was with the mechanics last friday for the same thing but worse where they did the plugs & points, lead connection to coil was loose, dwell timing. Car was fine since until I took it on a longer trip (Kew to Eltham and back). Will advise report from mechanics on monday as they have it over the weekend as well. Nickc
    353
    Mine used to play up when hot if had the wrong heat range plugs.They have a different plug to the carby cars but a lot of the catalogues don't show that. A very hazy memory says that the TI plugs ended in 6 and the carby ones in 8??? Then as per Robs above. Neil
    Fellow Frogger! stew's Avatar
    Apr 2011
    brisbane
    507
    What is usual is fuel starvation. Some things to check, or politely suggest to repairer,
    1/ Fuel filters. 1 near electric pump, one in engine bay cartridge, 1 in fuel delivery line banjo fitting bolt.
    2/ Fuel pump delivery failing due to worn brushes etc. in fuel pump.
    3/ The stupid ceramic fuse and holder can have a resistance in them. If it early I recall the 2nd from the bottom gets hot and separates. Cools and away you go. Replace with an in line fuse across the box.
    4/ Another usual occurrence is the points close up due to worn dist cam or shit rubbing block on points. Dwell is 57 on Ducellier, 52 on Bosch. Plug gap is 0.6mm. Also ignition leads may be loading the coil if the leads have small open circuits and coil overheats. Check inside coil high tension for oil or swollen boot on the coil lead. Clear overheating sign.
    5/ To measure fuel pressure access the delivery line at the pump and it needs to be at least 24 to 30 psi.
    6/ Alternator wiring from alternator to starter can be stuffed too, although you should notice the Volt gauge down in the red.
    I got sworn at once for not prewarning the long term owner of an LTi that the needle of the gauge with minus and plus signs needs to stay away from the minus other wise LTi stops. I don't suffer with those kind of fools any more! Too old. Isn't strange how d###heads stick in the memory?
    7/ If all else fails I'll dig up the Kugel Fischer bible. Perform the Ancient Ti Tribal fertility dance in full Track Yellow and Avocado regalia and that will fix it.
    12,283
    make sure the coil is correct for the car
    you want 26thou plug gap and 14thou points gap
    these settings are what i found to be best for a TI
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Feb 2011
    106
    thx neil stew & PugRambo, I shall pass these on & advise thread of fix given
    NC
    con
    con is offline
    sydney, nsw, australia
    526
    Quote Originally Posted by neil s View Post
    Very close Neil.
    From very limited experience, NGK BP6ES is usually used in carby models. BP5ES (a hotter plug) seems to be better for the Ti.
    con...
    Feb 2011
    106
    Quote Originally Posted by pugrambo View Post
    Thx PR, what's that in metric?
    Nc
    Perth Western Australia
    2,712
    con,
    The plug numbering system can be confusing. NGK BP5ES are the "colder" plug. Perfomance versions of most engines will use a cold plug.
    con
    con is offline
    526
    con,
    Some manufacturers' numbering systems are opposite to others. For Champion, Autolite etc. the higher the number, the hotter the plug.
    For NGK, the higher the number, the colder the plug.
    http://www.ngkspark.com.au/sparkplug_tech.php#
    (see "Heat Range Explanation").
    con...
    Apr 2011
    brisbane
    507
    Nup, the colder plug for NGK is 6.
    5 is hotter.
    2,712
    I defer to all re the NGK numbering.
    The old Bosch numbering system was a bit long winded. IE. The Bosch WI 175 were a common fit for most engines. The numbering advanced as the plug got colder. IE. WI 200. WI 225 and WI 240.
    I'm also sure the Champion numbering decreases as the plug gets colder. 504 Carb N9Y [C]. 504 TI N7Y [C] ?
    19,517
    Apr 2011
    brisbane
    507
    Vindicated.
    Feb 2011
    106
    Thx again. Car back on the road running very well again. Rear fuel filter replaced and fuel lines cleaned was what I'm told we're done to fix it. not sure why that affected the car only when hot. I will ask. Haven't checked the plugs numbering. Will do that too. Nick
    Fellow Frogger! james h's Avatar
    Jan 2005
    Barossa Valley
    170
    Keep a spare firewall fuel filter (and a 10mm spanner) in your glove box.
    (The only thing that has ever let me down on any TI engined car I have ever owned is that bloody filter getting blocked.)
    205,405,505,306
    Feb 2011
    106
    thx JH
    i might do that
    12,283
    Quote Originally Posted by james h View Post
    the rear filter next to the pump will give in long before the firewall filter
    if the car coughs you can bet the rear filter is blocked
    the firewall filter should be changed every 15k from memory
    1 x 2018 3008
    mullumbimby
    879
    Same same....but the filter next to the fuel pump is worth changing first as it gets first gulp of the fuel
    Boolarra vic
    44
    My first 504 in the early 90s still had its original Coil but it had lost its oil. Had a crack in the plastic top. It still looked OK but once it got hot, and it got really hot from memory, it started breaking down as you describe. Worth checking if you are trying to sort out ignition issues.
    Trevor
    Feb 2011
    106
    Quote Originally Posted by trevhoare View Post
    Trevor
    thx Trev
    the coil is newish
    I had a 2nd hand one put in recently by paris
    i did have major coil issues a while back when i had the wrong one installed by someone else
    burnt out the points within weeks repeatedly until diagnosed
    Major hassle
    there's oil in the coil?
    N
    con
    con is offline
    526
    Replace the capacitor (with correct "farads") as per Robs suggestion or there is a a tear in the diaphragm rubber of fuel pump (had same problem with the carby version of 504 - assuming the Ti is similar).
    con...
    Feb 2011
    106
    the car has been good since the repair (replacing the fuel filters)
    the reason for the missing only when hot was the rear fuel pump heating up trying to push fuel through the dirty filter(s)
    the hot engine was a red herring
    NC
    Feb 2011
    106
    Quote Originally Posted by nickc View Post
    NC
    heating up & struggling i assume
