306 Front brakes
    Member 01YLE's Avatar
    Jun 2012
    Bris QLD
    89
    Default 306 Front brakes
    I am wondering if 306 brakes can be fitted straight onto a S1 205 gti (with the smaller hub) i planned to change the rotor and caliper frames to the bigger 306. but someone was telling me that i had to fit 16in wheels to fit them in. i currently have 306 15in fitted. figure if a 306 had 15in and the brakes fitted in them this wouldn't be a drama.
    can this work easily or is there a bit of messing around?
    Lyle
    1000+ Posts N5GTi6's Avatar
    1,120
    Surely if the disc is on the same centreline, and that centreline fits inside a 306 with 15in rims, then the same disc on a 205 would also have the same centreline, with the caliper mounted at the same distance from the centreline, and so the same 15in wheel would fit on a 205 ???? phew.....
    Justin
    '07 C3 Exclusive
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
    Jun 2012
    Bris QLD
    89
    yes thought this was straight forward swap.
    So no one else has had any problems?
    Lyle
    Fellow Frogger! Aprilia's Avatar
    Apr 2012
    Rosebud Vic.
    175
    I have done that conversion on my 91 205 si with 13"dia wheels everything just bolted straight on and it was an improvement, at some stage I will also change over the mastercylinder because it is a larger diameter and will improve the brake response.
    Jun 2012
    Bris QLD
    89
    Cheers for your feed back guys. well that is 2 confirmed... now have to convince this fella to sell them me.
    I do plan to change master cylinder eventually, but just going baby steps at a time.
    Lyle
