Track Car Dyno Results
Results 1 to 14 of 14
    7,567
    Default Track Car Dyno Results
    I finally got my 205 with it's new engine and Haltech 500 on the dyno last week. I came away with mixed results however, as the TDC sensor was playing up. There was a lot of interference/noise resulting in "missed" trigger events. With some massaging of the software we did get it working, but not over 6500. The result recorded was 123kW @ 6500. I'm happy with that, as it use to make 123kW @ 7500. So there's plenty left to find.
    Rather than use a Motronic sensor, Haltech suggested replacing it with a hall effect trigger that will fit in the same hole and use the Motronic teeth. It should be a lot more reliable with a 12V square wave. I have to make an adapter to mount it, then it's back to the dyno to finish off the mapping.
    http://www.haltech.com/store/index.p...ct-sensor.html
    Don't remind me!
    16,599
    What was causing the noise - ignition?
    7,567
    Just a faulty sensor I hope.
    Far North Queensland
    1,494
    Thats pretty impressive Peter, you will enjoy playing with the extra performance.
    Yesterday I was again in Cairns for the Auto Show Spectacular.
    Competed in the Time Trials again and had a ball exploring the handling potential of the 205.
    Nowhere near the limit yet but its so controllable and so much fun.
    One of the other events was a dyno shoot-out.
    $40.00 for a short run and printout.
    No way I was going to compete against the big horsepower vehicles there but I thought it was good value to get an idea of how the engine is performing.
    Came out at 122 HP at the wheels at a calculated 6,000 rpm and max torque of 173 FtLb around 5000 rpm.
    Strangely there is a dip in the torque curve between 3,000 and 4,000 rpm, just where the seat of the pants tells you that its comming on strong.
    The dyno operator advised that the figures for both HP and Torque were conservative as the car had to be driven up onto the dyno instead of backed up so that the front wheels were in contact with the rollers. This meant that the wheels were trying to climb up onto the idler roller instead of the grouved sensor roller.
    Its a small world. The dyno operator is the son of the previous owner of "French Connection".
    Peter, assuming the calculated rpm is correct (no electrical connections were made to engine) would the chip you sell for use in conjunction with your cam give more HP at higher revs.
    The type of competion I'm doing benefits from low rev torque in second gear, would the chip compromise that?
    Paul
    “A straight is merely the distance between two corners.”
    “Corners: radar free zones.”
    Current: Peugeot 205 GTi Mi16 1987
    Peugeot 205 Si, one red one silver, both 1991.
    Peugeot 504 Wagon, V6 and 5 speed gearbox.
    Isuzu (Holden) Rodeo, 4WD dual cab, extended chassis.
    Past: Goliath, Isuzu Bellett, Austin A30, Peugeot 203, 403, 404, 504,505.
    Subaru 4WD wagon, Toyota Hilux Dual Cab Diesel 4WD.
    Makotrac 205 GTi 06-05-2012 best lap 1 min 20 sec.
    7,567
    122hp (or 91kW) is very good for a DFW with just an inlet cam change. The chip improves midrange torque by revised ignition timing.
    1,494
    Thanks Peter I will check out which computer it has and get back to you with an order.
    Could I get your opinion on the dip in the torque curve please.
    Is this the way it should be?
    I'm guessing your chip would correct the dip?
    Track Car Dyno Results-jse_09-17-2012_12%3B50%3B36pm.jpgTrack Car Dyno Results-jse_09-17-2012_12%3B57%3B20pm.jpgPaul
    Fellow Frogger! Kyle's Avatar
    Sep 2004
    Muswellbrook
    873
    Default Re: Track Car Dyno Results
    Thread hijack
    Peter I am fitting a platinum 1000 to my hti6 in a few weeks, should I be getting the same hall effect sensor or will I be okay with the oem one?
    7,567
    Attached is a DFW showing standard and Stage I inlet. The dip is natural and is caused by the lack of CR. The D6C is flatter. The chip certainly improves that area, but not as much as a good dose of compression.
    Kyle, your TDC sensor should be fine. I've used the OEM sensor many times. Since I have to buy a new one, I thought I'd go hall effect.
    Attached Thumbnails Attached Thumbnails Track Car Dyno Results-stage1_cam.jpg
    1000+ Posts Dave's Avatar
    Apr 2001
    1,339
    Ever get this back on the dyno with the new sensor Peter?
    What block/heads are you using in the 205 these days?
    Dave
    7,567
    No, haven't been back to the dyno. The miss turned out to be from a faulty cam sensor. It now pulls cleanly to 8000, so it would pull more than 123kW. Block is S16, head is Mi16 with mods.
    Jan 2011
    Traralgon
    649
    I'm in PNG at the moment so don't have access to data, but I can tell you that the crang angle sensor in my XU9 is exactly the same as one from a Hyundai Excel. When the part comes in the Korean bag, it is much MUCH cheaper than the French model. I'm pretty certain i have posted the part number here once before - so you may be able to find it via search tool - if it is of any interest.
    racing 405
    1:59:09 last time at Phillip Island - less than standard Mi16.
    7,567
    The XU10 cam angle sensor is also identical to Hyundai.
    Apr 2001
    1,339
    Damn, Ken W just imported a couple of spare Xu10 CAS. I hope he doesn't read this
    Dave
    Jul 2004
    803
    Some prices to compare. I like the little stubby ones without the flying lead. Looks like they would work.
    http://www.ebay.com.au/sch/i.html?_t...at=0&_from=R40
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
