Quick 1/4 Clio 172
Results 1 to 13 of 13
    Sep 2004
    90
    Default Quick 1/4 Clio 172
    A fellow I know who has done a lot of open wheeler racing recently purchased a 172. He decided to do a 1/4 mile sprint, and after much experimentation finished with a time of 14.68 - stock car remember.
    The 'secret' ? 13psi front 40psi back!
    79
    Quote Originally Posted by 911s
    R u sure that was it mate???? That is a very quick time for a car that does 15.5's....
    I believe it when i see the time slip!!!!
    Jaime....
    "Honda makes power for the hell of it, Renault makes power you can use".
    1,160
    Quote Originally Posted by RCS 20L
    hmmm i thought it was 15.3 172 & 15.1 182?
    Sep 2004
    90
    Well, in motorsport, this guy is definitely a 'Top Gun'. He has an unusual feel for cars. Only he would have thought to adjust tyre pressure to that extent.
    Fellow Frogger! WRCPUG's Avatar
    May 2002
    Glen Iris, Melbourne
    1,035
    Crazy stuff
    What was his 60 foot time and MPH?
    PEUGEOT 306 GTi6 (1997-1999 HYBRID)
    105.4kw (141HP) ATW
    2:09 Phillip Island (Toyo Street Tyres)
    2001 YAMAHA YZF-R6
    119HP
    1993 MITSUBISHI 3000GT Twin Turbo
    300BHP
    STOCK-14.006 @97.4mph HEATHCOTE
    STOCK-1:15 CALDER Long Circuit (Stock Street Tyres + Stock Pads :banghead )
    (For Sale)
    Nov 2002
    Golden Beach, Queensland
    2,763
    You'd have to believe in he science of what he did.
    High pressure in rear tyres, would stop the car lifting the nose as much when power is applied. I wonder if the fronts would ride up like the rear tyres on Drag cars do, when they spin faster they get taller. Could have been how he reduced his time by drive wheels becoming larger in diameter towards the end of the 1/4???
    I really have anything is possible.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    79
    Quote Originally Posted by nate
    Sorry Nate.... Was just rounding in 5's, and ur right a 172 does do 15.3...
    But wiping off nearly a whole sec... damn thats quick... At those speeds he will beat me by 10 car lenghts.... What the
    Jaime....
    Fellow Frogger! biologist's Avatar
    867
    Stopping that weight shift to the rear wheels would certainly prevent a lot
    of wheel spin and could be where all the time savings are made...
    cheers,
    Biologist
    A
    one Megane Family
    6,663
    A softer tyre gives more straight line traction, that's all.
    2003 PEUGEOT 206 GTi
    Fellow Frogger! ClioF1's Avatar
    Mar 2005
    Western Sydney
    172
    40 Psi isn't that extreme, I run 39 in the front all the time. There is no way that stopped the rear compressing under take off. The only way to stop that is suspension - an old trick is to put chocks in the rear springs.
    13 Psi is very low though, maybe I will have to give it a go if I get my car to WSID one day.
    2005 RENAULTsport Clio 182 Cup F1
    867
    Quote Originally Posted by Stuey
    Quote Originally Posted by ClioF1
    40 Psi isn't that extreme, I run 39 in the front all the time...
    ..13 Psi is very low though, maybe I will have to give it a go if I get my car
    to WSID one day.
    Agree and Agree, years ago when in a pit crew running a street car at
    Waneroo we used to keep the race tyres at 38-40 psi.
    (These were very expensive buffed road tyres not race slicks)
    But there is no way I'd want to corner hard in a Clio, or anything
    for that matter, with only 13 psi in the tyres..
    I'd be real interested to see how much weight shift there is with
    such low fronts as the squigy tyres would grip harder rather than
    spin madly? and I doubt there would be as much weight transfer
    but I'd love to see it.
    cheers,
    Biologist
    A
    one Megane Family
    Simon's Avatar
    6,203
    Quote Originally Posted by biologist
    cheers,
    There would be no change in weight transfer just with the altered tyre pressures. What would be happening is that the soft front tyre would be altering from say a W shaped underinflated form to a U shaped form as the weight comes off the front end through acceleration and the weight transfers. That way the tyre would constantly grip the track rather than spin as more of the tyre tread comes into contact with the track. The high rear inflation would just reduce the overall drag of the car on the ground as it would be virtually tippytoeing on the centre of the tyre.
    Also it would have an awful lot to do with the technique too, too much gas and you could probably start smoking the underinflated bags quite nicely off the line!
    867
    Quote Originally Posted by Simon
    OK I see what your saying, it would certainly take a bit of practise to
    achieve a good launch but obviously if the report is true can be quite
    effective, in a straight line.
    In the end though wouldn't it just be easier to get some real slicks and
    see what happens??
    cheers,
    Biologist
    A
    one Megane Family
